Hello everyone, I’m looking for reliable methods to make IKEA Billy shelves more child-safe and stable. Specifically, I want to prevent the shelves from tipping over, as we have small children at home who often like to pull on or climb the shelves. Besides securing the unit to the wall, I’m also wondering if additional measures like gluing the back panel, adding reinforcements inside the shelf, or using certain floor pads could help. It would be great if you could also address the common weaknesses of the Billy shelves and share practical tips to make the unit more durable and safe in the long term without affecting the appearance too much. Thanks in advance!
Using tension rods as an alternative to wall mounting is problematic in a child-friendly environment. They generally do not provide comparable stability against tipping because their support relies on friction, which is often exceeded by stresses caused by climbing or pulling. For rental properties, I recommend special screw-free furniture restraints that use rubber pads and clamping mechanisms, which can be easily removed while still offering good hold. Additionally, the back panel should be reinforced, for example with extra thin metal brackets on the inside, to improve lateral stability.
REJON schrieb:
Are there any recommendations? In rental apartments, I often use tension straps without clamps, which are fixed at the top to the shelf and at the bottom to the door or window frame. This way, you avoid drilling holes.
REOHEINRIC25 May 2021 09:58A brief addition: The structural stability largely depends on using the correct mounting materials. For drywall partitions, heavy-duty anchors or so-called "molly bolts" are recommended, as they provide high tensile and shear strength. Fastening should be installed vertically and must not be too short. Additionally, brackets with larger bearing surfaces are more stable.
Concerns about drilling into walls in rental apartments can be minimized by patching before moving out, but such fixings are clearly superior in terms of safety compared to purely clamping systems.
Lorukeo schrieb:
Tension braces as an alternative to wall mounting are problematic.Absolutely correct. Tension systems are rather an additional measure or a compromise solution in special cases and do not replace professional mounting.
As a supplement: If wall mounting is not possible, one could also use profiles that are invisibly and reversibly connected to the shelving unit using adhesive techniques (construction adhesive, two-component adhesive). Whether this provides the necessary long-term stability depends on the adhesive and the usage—small children can exert very strong pulling forces. In such cases, I recommend combining this with reinforcement of the back panel and precise floor leveling to minimize the risk of tipping.
One more note: Be careful when screwing individual shelves to avoid cracks in the material. If in doubt, it is better to use thin wooden dowels.
