ᐅ How can I make BILLY shelves childproof and stable?
Created on: 24 May 2021 10:23
REJON
REJON
24 May 2021 10:23
Hello everyone, I’m looking for reliable methods to make IKEA Billy shelves more child-safe and stable. Specifically, I want to prevent the shelves from tipping over, as we have small children at home who often like to pull on or climb the shelves. Besides securing the unit to the wall, I’m also wondering if additional measures like gluing the back panel, adding reinforcements inside the shelf, or using certain floor pads could help. It would be great if you could also address the common weaknesses of the Billy shelves and share practical tips to make the unit more durable and safe in the long term without affecting the appearance too much. Thanks in advance!
Daledra
24 May 2021 10:47
The most important thing is a secure wall mounting using the supplied brackets. Otherwise, the shelf can tip over very easily. Additionally, you can install small corner strips at the back to reinforce the structure.
REOHEINRIC
24 May 2021 11:12
The stability of BILLY shelves primarily relies on wall mounting. To prevent tipping, it is recommended to first properly install the supplied brackets using appropriate wall anchors and screws. Special anchors are required for wooden or drywall constructions. Additionally, it is advisable to secure the back panel to the side panels with small nails or screws to further reinforce the structure. To compensate for uneven flooring, felt or rubber pads can be placed under the shelf feet. This also reduces noise when opening the shelf doors, if present. Alternatively, metal angle brackets can be used to strengthen the connection between the floor and the shelf. It is important to carry out these measures without causing any damage to the furniture structure.
Parbo
24 May 2021 12:51
I would like to discuss in more detail the topic of stabilizing BILLY shelves, especially from the perspective of being "child-friendly." This means ensuring both safety and durability without creating unnecessary hazards for children.
1. Wall attachment: This is crucial. BILLY shelves usually come with wall-mounting hardware that must be installed. The quality of anchors and screws should match the wall type. For example, drywall requires cavity anchors or special furniture anchors.
2. Reinforcing the back panel: The back panel of the shelf is relatively thin and also serves as diagonal bracing for stability. Occasionally gluing the back panel edges with wood glue can increase torsional rigidity. Additionally, screwing in extra metal brackets inside can improve overall sturdiness.
3. Floor conditions: BILLY shelves often stand on carpet or hardwood floors. On uneven floors, leveling with small rubber pads or felt gliders helps minimize wobbling.
4. Safety around children: Since children often pull on or climb furniture, loose shelves should be avoided. These can be secured with small screws to prevent removal. Retrofitting screws in hidden parts of the shelf also enhances overall load-bearing capacity.
5. Alternative stabilizers: There are special furniture stabilizers, such as tension rods that clamp from underneath against the back or sides without screws. Depending on the model, these can be useful when wall mounting is not possible.
My question to the group: Has anyone used these tension systems already? What are your experiences, especially in homes with children? What are the limitations of these solutions?
Laurence
24 May 2021 13:39
Hello REJON, I have two BILLY bookcases at home and also small children. My most important recommendation is to always secure the bookcase to the wall. This is a simple and effective measure to prevent tipping. I used the metal brackets that come with the bookcases.
Regarding the back panel, I didn’t apply any additional adhesive, but I fixed the panel with small nails to keep it stable.
A good tip for extra safety is to load heavier items at the bottom of the bookcase and avoid overloading the top shelves with heavy toys.
If the bookcase is on carpet, just put non-slip pads or felt pads underneath to improve stability.
As Parbo already mentioned, I would consider tension braces only as a supplement—they do not replace wall fixing.
REJON
24 May 2021 14:03
Thank you for your previous answers; they have been very helpful. @Parbo, your detailed description is exactly what I was looking for. You asked about experiences with tensioning systems: I haven’t tried any so far because I have some concerns about whether they really prevent tipping in everyday use or if children can easily undo these safety devices. How stable are they in practice? I have the shelf in a rental apartment, so I want to fix it to the wall with as little damage as possible. Are there any recommendations for that?
