ᐅ How can I change the color of Billy bookshelves?
Created on: 29 Sep 2015 18:07
SAUTILMAN
Hello everyone, I have some IKEA Billy shelves at home that I would like to change the color of to better match my interior. My question is: How can I change the color of Billy shelves without damaging their stability or surface? I am looking for solutions that are doable for amateurs, such as painting or applying adhesive film, but I am also open to tips on suitable materials and techniques to ensure the result looks professional and lasts as long as possible. Additionally, I would like to know if there are any preparations needed before starting the color change and if there are specific products that work particularly well. Looking forward to your tips and experiences!
Tarbi
30 Sep 2015 09:01
GLALEO schrieb:
Painting works great! What helped me was to sand the surface well first.
I consider that a critical underestimate, since the Billy shelf is not primarily designed for such modifications. Sanding changes the surface, can lead to moisture absorption, and may affect stability over time. What about sealing, for example with sealers after painting? Also, there is the question of whether this devalues the original furniture if you ever want to restore it.
PIDAN schrieb:
A fine grit (about 220) is sufficient. Afterwards, you should use a suitable primer.
I think that makes sense; however, I especially recommend checking the materials for solvent compatibility to avoid swelling or damage to the melamine surface. Self-adhesive films are often easier to remove and more environmentally friendly. What are your thoughts on wrapping versus painting regarding durability and appearance?
Fredlo
30 Sep 2015 12:38
Wow, this is a really great discussion! 🙂 I just want to add that when it comes to adhesive film, handling is crucial: A high-quality self-adhesive film, such as vinyl, is often easier to apply than you might expect. Measuring accurately and gently warming the film are important to ensure it fits well around edges. You can use a squeegee to push out any air bubbles. If you ever want to move, you can usually remove the film quite easily. Of course, a paint job often lasts longer, but for small visual updates, using adhesive film is really great! 🙂 So, if you’re worried about paint and odors – give adhesive film a try!
minjan
1 Oct 2015 07:12
Painting: Sand the surface, apply a primer, paint with a matte finish, done.
Wrapping: Clean, smooth surface, press the wrap firmly.
Otherwise: Both methods work; wrap is easier to remove.
TEBILO
1 Oct 2015 09:45
I will address the topic in much more detail. If you want to change the color of your Billy shelves in the long term and also care about a professional finish, I recommend the following step-by-step guide:
1. Disassembly: Take apart the shelves as much as possible to ensure all surfaces can be properly worked on.
2. Cleaning: Remove dirt and grease from the surfaces using a mild solvent such as isopropanol.
3. Sanding: Lightly sand with 240-grit sandpaper or a sanding pad. Do not sand too deeply to avoid damaging the melamine coating; just roughen the surface slightly.
4. Remove dust: Use compressed air or a microfiber cloth.
5. Priming: Use a primer specifically designed for melamine-coated surfaces or plastics. This primer improves paint adhesion.
6. Painting: A two-component acrylic or PUR spray paint is more complex to apply but recommended for a durable result. Alternatively, you can use synthetic resin paints with a brush or roller.
7. Intermediate sanding: After the first coat, lightly sand with fine sandpaper (grit 400-600).
8. Apply a second coat of paint.
9. Sealing: Apply a matte clear coat to protect the finish.
If you have no experience with painting, it is also possible to have the shelves done by a professional service. Although more expensive, the result will be very professional.
I wonder: Are you already familiar with handling spray or brush techniques, or should I provide detailed instructions on that as well?
