ᐅ How can I carry out MALM repairs myself?
Created on: 15 Sep 2022 08:17
hichamju
Hello everyone, I am planning to carry out some small repairs on my Malm dressers myself and am looking for tips and advice from you. Specifically, it involves adjusting the drawer slides, replacing damaged side panels, and repairing loose screw connections.
Does anyone have experience with disassembling and safely reassembling Malm components? Are there any special tools that work particularly well? Any advice on how to properly handle particleboard surfaces to avoid damage during repair work would also be very helpful.
How can one especially avoid compromising the stability or appearance permanently after a repair? Thanks in advance for your support!
Kukar
16 Sep 2022 11:26
hichamju schrieb:
Does anyone have recommendations on how to tighten screws again without having to replace the furniture parts completely?
Yes, you can use wooden dowels or press-in nuts for particleboard. First, fill the screw holes slightly, then glue in the dowels. This holds much better and avoids the need for new panels.
CARLA
16 Sep 2022 14:44
In addition to Kukar's advice: For screw holes that have become stripped, a special repair kit with injection resin or two-component wood filler works very well. The material fills the hole and hardens firmly. After that, it is possible to screw in safely again.
Threaded inserts are generally a good option if there is enough space and the furniture construction allows it. However, installing them requires special tools (drill, installation tool) and some experience.
If you do not have a cordless drill, be careful when using threaded inserts to avoid further damaging the chipboard.
