ᐅ How can I maintain Malm furniture using common household products?
Created on: 11 Jan 2021 08:47
erkmen49
Hello everyone, I am looking for recommendations on how to care for my IKEA Malm furniture effectively and gently using simple household products. The furniture is made of coated wood, and I want to avoid using harsh chemicals or damaging the surface. It is important to me that the care not only removes surface dirt but also addresses minor scratches or dull spots without affecting the paint or coating. Are there any proven home remedies or techniques you would recommend for regular cleaning and refreshing? I would appreciate any tips, including advice on dosage and frequency of application!
Using oils such as linseed oil or olive oil on melamine or lacquered furniture surfaces is generally not recommended in practice. These surfaces are non-porous and do not absorb the oil; instead, it forms a film that can attract dirt and increase the visibility of dust.
A better option is to use silicone-based care products or specialized furniture polish designed for laminated surfaces.
Regarding cleaning: a mild soap solution and microfiber cloths are sufficient, followed by thorough drying. Avoid wet edges to prevent swelling.
For minor scratches, repair kits with color and texture fillers are the most effective solution.
BEMAU schrieb:
A better alternative is silicone-based care products or special furniture polish designed for laminated surfaces.That’s correct; silicone-based polishes are specifically designed for smooth, hard-to-penetrate surfaces and provide protection against dust. However, I recommend using these polishes sparingly to avoid forming a sticky residue.
For users who prefer to use only household products, wiping with a lightly dampened cloth followed by quick drying remains the safest method.
@erkmen49: I would also advise using oil sparingly on light-colored surfaces and testing it on inconspicuous areas first.
Once again, regarding the discussion about the effects of oils and polishes: It is important that maintenance remains superficial and should not be confused with traditional wood care methods used for solid wood.
This is a crucial point. Such products should be avoided, and it is better to use neutral cleaning agents instead.
Additionally, I would recommend polishing the edges, which are particularly sensitive, manually with a dry cloth, as this reduces moisture buildup there.
erkmen49 schrieb:
that no aggressive acids should be used,
In summary:
The following steps are recommended for the regular cleaning and maintenance of Malm furniture using household products:
1. Wipe with a soft, slightly damp microfiber cloth and a neutral dish soap
2. Immediately dry to prevent moisture damage
3. For minor scratch repairs: use repair pens, as household products have little effect in this case
4. Use oil or wax treatment very carefully and preferably only on untreated solid wood parts, not on coated surfaces
This approach minimizes the risk of damage and preserves the appearance of the furniture.
