SKENDERJON1 Jul 2015 14:28Hello everyone,
I have some Billy bookcases from Ikea at home, but the main issue is that my floor is not completely level – this causes the shelves to wobble slightly, especially when they are fully loaded. My question is quite specific: How can I better secure my Billy bookcases on these uneven floors to reliably prevent tipping or wobbling?
I have already considered different types of shims or pads, but the solution should be stable in the long term and preferably not require major structural changes to the shelving units themselves. I look forward to your tips and experiences!
SKENDERJON schrieb:
How can I better secure my Billy shelves on these uneven floors to reliably prevent tipping or wobbling?Hello SKENDERJON,
this is a classic issue, as Billy shelves on uneven floors can quickly become a safety hazard. I’ll go through possible solutions step by step:
1. Adjustable leveling or furniture feet: There are special adjustable furniture glides that you can screw under the legs. This allows precise height adjustment, especially for minor floor unevenness.
2. Plastic or felt pads with layering: For smaller irregularities, felt pads or thin plastic sheets, which can be layered as needed, sometimes work. However, this can become unstable with larger unevenness.
3. Wedges made from wood or plastic: You can cut small wedges to place under the feet. This has two advantages: you can customize them individually, and they are relatively inexpensive.
4. Wall fixing: The safest method is securing the Billy shelf to the wall using the supplied metal brackets. These prevent tipping forward or sideways, which is particularly important on uneven floors.
5. Build a base plate: If the floor is very uneven, you might consider placing a leveled wooden board under the shelf. The board should be leveled and able to provide a stable surface for the shelf.
Just a quick question: How severe is your floor unevenness? And have you already fixed the shelf to the wall? The latter is crucial for safety.
Best regards, fidasi
praWarre692 Jul 2015 09:05fidasi schrieb:
The safest way to secure the Billy shelf is to fix it to the wall using the supplied metal brackets.That's absolutely true, fidasi! When a Billy shelf starts to wobble, it quickly feels like being on a small sailboat in a storm 😉
When I set mine up, I simply used small, self-adhesive rubber pads that you can place under the shelf’s feet in combination. With the wall mounting, it worked perfectly. The rubber pads also help absorb minor vibrations or movements.
Also, it doesn’t hurt to check the floor with a spirit level before placing the shelf. If you don’t mind spending a little extra time and money, having a good baseline is definitely worth it.
And of course, fidasi’s wedges are great too—I believe a bit of DIY never hurts. That good feeling of seeing the shelf stand firmly is priceless :-)
How big is your Billy? The larger it is, the more critical a secure base becomes.
Good luck!
SKENDERJON schrieb:
How can I better secure my Billy shelves on uneven floors to reliably prevent tipping or wobbling?I’d like to add to that and share a few basic tips:
First, it’s important to understand that Billy shelves are not designed for heavy loads without being anchored to a wall. Wobbling caused by uneven floors can at least be minimized by adjusting the feet. Adjustable furniture feet or small shims can help compensate for floor irregularities.
If you can’t secure the unit to the wall (for example, in a rental property where drilling is not allowed), try adding heavy items to the lower shelves. This lowers the center of gravity and reduces the risk of tipping.
You can also place non-slip rubber pads under the legs to improve grip. Make sure there are no gaps under the shelf legs, as this will otherwise allow wobbling to continue.
One more tip: regularly check that the screws for the shelf supports or the shelves themselves remain tight. Loose connections can also cause wobbling.
I hope this helps!
Best regards, nikian
