ᐅ How can I better protect Malm furniture from scratches?
Created on: 26 Oct 2021 07:44
pra37
pra37
26 Oct 2021 07:44
Some time ago, I bought the popular Malm furniture from IKEA, but I have become a bit concerned about the many small scratches forming on the surfaces. My question is: How can I better protect Malm furniture against scratches? I would like to know which proven methods exist to make the surface more durable and resistant to everyday wear, without changing its appearance or restricting its use. Are there special care products, protective films, or other tips you would recommend? Additionally, it would be helpful to know how to treat the furniture preventively before any actual damage occurs. Thanks in advance for your answers!
SUDAN
26 Oct 2021 08:11
Hello pra37,
I’m happy to help you with a brief overview on how to effectively protect Malm furniture from scratches—step by step.
1. Cleaning: It is especially important to clean the surface thoroughly but gently. Avoid abrasive cleaners; instead, use a damp cloth with a mild dish soap.
2. Protective film or felt pads: Particularly in areas with frequent movement or contact, such as drawers or resting surfaces, self-adhesive protective films or felt pads can help prevent scratches caused by friction.
3. Care products: There are special furniture waxes or care oils that can be applied to the surface and create a thin protective layer. Please make sure these are fully compatible with laminated panels, as Malm furniture often consists of melamine.
4. Preventive measures: Avoid placing heavy or sharp objects directly on the furniture. Use coasters, tablecloths, or transparent plastic mats, especially on desks or bedside tables.
Summary: Regular gentle cleaning + thin protective layers + physical protection (felt/film) provide the best overall protection.
If you like, I can also provide specific product names or sources. Hope this helps!
Laurence
26 Oct 2021 09:36
Hello pra37,
I completely agree with SUDAN and would like to add an explanation as to why Malm furniture tends to be relatively prone to scratches: the surfaces are usually coated with a thin foil or melamine resin, which is durable but also sensitive to sharp edges or rough materials.
Therefore, while this furniture is stylish and affordable, it requires some care.
Regarding care products: I have had good experiences with furniture polishes designed specifically for veneered or coated surfaces. These create a light protective layer, and regular polishing helps maintain the appearance.
One more tip: hemp pads work well for gently removing fine scratches if they are already present. This can significantly improve the look.
It is important to avoid harsher cleaning agents, as they can cause the surface to wear out even faster.
I hope this gives you some additional guidance for protecting your Malm furniture.
sarGabriel
26 Oct 2021 10:05
Hello pra37,
Use felt pads on all furniture contact points and apply thin protective films on surfaces that are frequently subjected to stress. Regular cleaning without abrasive cleaners helps. This effectively prevents scratches.
kaju67
27 Oct 2021 12:19
SUDAN schrieb:
Especially in areas with a lot of movement or contact, such as drawers or resting surfaces, self-adhesive protective films or felt pads can be helpful.
Just wanted to quickly add: Yes, that’s exactly how I do it as well, and I can fully recommend it. Those small felt pads are basically the bodyguards for the furniture! 😉
I also have a very thin, transparent plastic film on the tabletop of my Malm desk. That way, scratches feel like ninja attacks – they just bounce off! 🙂
They’re not expensive, and you barely notice they’re there. Comfortable and gentle on furniture, perfect for anyone who doesn’t want to constantly worry about scratches.
Parbo
28 Oct 2021 15:47
to add to the discussion, here is a more detailed look at the materials and protection options for Malm furniture.
The surface is usually made of particleboard with a melamine resin coating. This coating is quite resistant to liquids and everyday wear, but mechanical stress from sharp edges or rough abrasion can quickly cause scratches.
If you want to better protect Malm furniture, I recommend the following approach:
1. Analyze the high-stress areas (e.g., tabletops, drawer surfaces, edges).
2. For flat surfaces, transparent protective films that can be cut to size and applied work well. High-quality films (for example, in furniture or paint protection) can last for months and are removable.
3. For edges, protective strips or profile films are a good option to reduce mechanical impact.
4. Alternatively, you can use furniture wax, but only products specifically approved for melamine surfaces, as some waxes can cause surface clouding or dull spots.
5. For existing scratches, fine sanding or polishing pastes can be used for spot treatment, although this requires some practice.
My last tip: Keep rooms dust-free and use microfiber cloths for wiping, as dust on rough surfaces can have an abrasive effect.
Are there any specific spots or situations where scratches occur more frequently for you? Then I can gladly provide more targeted advice.
