ᐅ How can I better protect MALM furniture from damage?
Created on: 9 Jul 2016 10:32
Tukristij3
Tukristij3
9 Jul 2016 10:32
I am looking for effective ways to better protect my Malm furniture from everyday damage. The surfaces are fairly durable, but I often notice small scratches and dents on the edges and drawer fronts that accumulate over time. I am particularly interested in whether there are specific care products or protective films that can reliably prevent this kind of damage.
Additionally, I wonder if certain handling practices (when opening drawers, placing objects on the furniture, etc.) can help significantly extend the lifespan of the surface. I would appreciate tips based on personal experience or well-founded recommendations!
Thank you in advance for your support!
tutan
9 Jul 2016 12:17
Hey Tukristij3,
great topic! 🙂 I also find it annoying when MALM dressers get small scratches so quickly – they are great pieces, but unfortunately not indestructible wood.
So, first of all: protective film is actually a good idea! There are transparent films you can stick onto the surfaces, like an "invisible bodyguard." They prevent scratches from happening in the first place. You can find them online and at some furniture or hardware stores.
Tukristij3 schrieb:
especially interested if there are special care products or protective films
Regarding care products: I definitely wouldn’t use oil or grease on MALM, as that tends to attract dust. Better to use a mild cleaning lotion and then wipe it with a dry cloth.
And when handling: open and close drawers gently, don’t slam them shut. Always place heavy objects on felt pads to avoid rubbing or scratching.
With these small measures, the wood (or the coating) will last much longer – guaranteed! 😉
Laluri
9 Jul 2016 14:03
Hello Tukristij3,
I would like to join the discussion and address some basic points that are especially important for furniture like MALM to prevent damage as much as possible.
First, regarding the surface: MALM furniture is often made of particleboard with a melamine-coated surface, which is quite resistant to scratches and moisture but can be damaged if handled improperly.
A good precaution, as already mentioned, is to use protective films or pads. These are also available by the meter, which is helpful if you have large tables, for example. I would generally avoid placing hard or sharp objects directly on the surface without any protection.
tutan schrieb:
Open and close drawers gently, don’t slam them shut
Closing drawers with too much force often leads to unattractive dents or chipped surfaces. If you like, you can attach small felt or rubber strips to the contact areas.
Cleaning products specifically designed for film or melamine surfaces are recommended. They clean gently and provide a protective layer that can help prevent minor wear.
If you want, I can gladly share some specific product recommendations—just let me know. I hope this helps you so far!
pauPierce
10 Jul 2016 08:47
Good morning everyone,
I’d like to revisit this topic since I have been using MALM furniture for several years and want to share some insights. It’s definitely worth approaching protective measures not just superficially but by understanding the physical properties of the surface.
The melamine resin-coated surface is durable against liquids and scratches but has some sensitivity to mechanical impacts and abrasion. The issue that often causes minor damage is micro-movements, such as sliding objects across the surface, which can create fine scratches.
Because of this, I strongly recommend:
1. Using pads like felt gliders under all items that are regularly moved or repositioned (e.g., lamps, boxes, or decorations) to minimize friction.
2. Protective polyurethane films about 0.2 to 0.3 mm (0.008 to 0.012 inches) thick. These are transparent, hardly noticeable visually, and provide very good protection.
3. Avoid placing very hot items directly on the surface, as heat can damage the coating.
4. Clean regularly with a pH-neutral cleaner to remove dust and dirt particles that can act as abrasives.
I have a few questions for you as well! How intensive is the use of the furniture? Are the pieces heavily used within the house, for example in a children’s room or office?
This could further influence the protection strategy.
I hope this helps for now!
JEREMIAH38
11 Jul 2016 19:29
pauPierce schrieb:
I have a few more questions for you! How heavily are the furniture pieces used? Are they subjected to heavy wear in the house, for example in children’s rooms or an office?
Hello everyone, I’d like to add something: especially with furniture that gets a lot of use or is located in high-traffic rooms, I’ve noticed that small damages are often more frustrating than large scratches.
I think it’s important not only to focus on protecting the surface but also on how the furniture is handled. My daughter’s MALM dresser has a few dents after several years because the doors are often slammed shut. I’m now making it clear to her that she should close the drawers and doors gently. Small habit changes make a big difference.
Also, I once tried using furniture wax myself – but caution is needed, as someone already mentioned. Not every product is ideal; sometimes it can make things worse.
Overall, I would recommend establishing a kind of “care routine”: take some time once a month to wipe the furniture with a damp cloth, remove dust, and quickly check any protective measures applied beneath.
Perhaps Tukristij3 can share which room the furniture is in and what the daily usage looks like?
flojo
12 Jul 2016 06:55
Summary and clear recommendations for protecting MALM furniture:
MALM furniture is made of melamine-coated particleboard, which is durable but has some vulnerabilities, especially at edges and joints. The most common types of damage are:
- Surface scratches from abrasion
- Damage caused by hard or sharp objects
- Impact marks from forceful closing of drawers or doors
To protect the furniture, I recommend the following measures:
1. Install soft pads (felt or PVC) under decorations and objects to reduce abrasion.
2. Use transparent protective films designed specifically for furniture surfaces to prevent finish damage.
3. Avoid placing hot or very heavy items directly on the surfaces.
4. Handle drawers and doors carefully and gently. Magnetic dampers can be retrofitted to help with this.
5. Clean regularly with mild, pH-neutral cleaners and avoid products containing grease or oil.
Tukristij3 schrieb:
gibt es spezielle Pflegemittel oder Schutzfolien die diese Schäden zuverlässig verhindern können
Care products: Only those explicitly intended for melamine-coated furniture. Protective films should adhere firmly, be scratch-resistant, and visually unobtrusive.
My recommendations are based on manufacturer information and my own long-term testing results.
If you have any further questions, feel free to ask.
