ᐅ What is the best way to clean IKEA Metod doors with integrated handles?
Created on: 23 Jan 2019 07:38
Soda45
Hello everyone, I have Ikea Metod kitchen cabinet fronts with integrated handles in my apartment and I am looking for the best way to clean these doors gently and effectively. It is important to me that the surface does not get damaged, as the white doors are relatively delicate, and that the integrated handles, where dirt and dust often accumulate, get thoroughly cleaned without too much effort. I would like to know which cleaning products and techniques you recommend here—whether special dish soap, all-purpose cleaners, microfiber cloths, or other tools are better suited. Which products and methods have worked well for you, especially regarding the integrated handles, which are a bit harder to reach? Thanks in advance for your tips!
Marion
23 Jan 2019 11:05
Avoid using aggressive cleaners altogether.
Mild dish soap is helpful; wipe off the water thoroughly afterward.
A small brush is suitable for recesses.
Garthre
23 Jan 2019 11:40
From my professional experience in kitchen maintenance, I can confirm:
- For daily cleaning, warm water and a mild dish soap are sufficient
- Microfiber cloths work very well because they pick up dirt without scratching
- For handle recesses, a small, soft brush or a toothbrush is suitable for removing dust and greasy residues
- Follow-up cleaning with a dry cloth prevents water spots
- Do not use harsh or solvent-based cleaners, as they can permanently dull the surface
Soda45
23 Jan 2019 12:22
Thanks for the many quick replies!
[@LuMarcel43]
LuMarcel43 schrieb:
Could someone confirm whether the IKEA care instructions truly reflect best practice, or if there are any newer experiences?
That’s exactly my question, especially since IKEA only mentions “gentle cleaning” for Metod doors but doesn’t specify how to clean the recesses without damaging the surface.
If anyone has experience with alternative cleaners, or even home remedies like vinegar or baking soda, that would be interesting. So far, I’m uncertain because vinegar is sometimes said to damage laminate surfaces.
botibo
23 Jan 2019 13:03
[@Soda45]
I would not recommend vinegar for use on foil fronts – it can dry out and dull the surface, even though its descaling properties are tempting.
A small amount of baking soda paste applied with a damp cloth can work on stubborn dirt, but test carefully first, as scrubbing might damage the coating.
Sometimes a mixture of dish soap and a splash of lemon juice helps, providing a fresh scent and a bit more grease-cutting power – but use sparingly and always wipe thoroughly.
farli
23 Jan 2019 14:26
Just to confirm:
Harsh cleaning agents and abrasives can cause irreversible damage to the surface of the foil.
[@botibo]
botibo schrieb:
I wouldn’t recommend vinegar for foil fronts – it can dry out and dull the surface
I completely agree.
If there are sticky or greasy fingerprints in the handle recesses, lukewarm water with a mild detergent, a soft toothbrush, and thorough drying afterwards will help.
LuMarcel43
24 Jan 2019 07:12
One more thought: How exactly do you manage water accumulation in the handle recess? Often, water or cleaning residue collects at the bottom edge, which can attract dirt over time.
I find it helpful to not only dry the doors after cleaning but also to carefully dab the recesses or work over them again with a small, dry cloth.
The temptation is strong to wipe the area roughly, but over time this can lead to discoloration or deposits.
