ᐅ What is the best way to install IKEA Metod cabinets in a tight or compact space?
Created on: 29 Apr 2022 08:42
Pelolo
Pelolo
29 Apr 2022 08:42
Hello everyone, I am planning to install IKEA Metod kitchen cabinets in my apartment to make the best use of the available space. However, the room is quite narrow, only about 2.10 m (7 feet) wide, with varying wall sections that make it difficult to arrange the cabinets in a straight line or the traditional side-by-side layout.
Therefore, I am interested in any experiences or tips you may have for placing and installing Metod cabinets in a tight floor plan—both regarding assembly and layout. Are there specific installation techniques, flexible combinations, or clever planning tips that help maximize a small space? Any advice on stability or making use of corners and angled wall sections would also be very helpful. Thanks in advance for your ideas!
sanjon
29 Apr 2022 09:10
In tight spaces, it often helps to choose taller cabinets instead of wider ones to make better use of the height.
Also, corner connections of Metod cabinets are sturdy; use the connecting fittings exactly as instructed to ensure stability.
Stay flexible by installing cabinets without a back panel – this allows you to adjust them without losing any space.
Gafiel
29 Apr 2022 11:45
Hello Pelolo,
Regarding the topic of "IKEA Metod cabinets in tight layouts," there are some important details to consider to ensure both stability and functionality.
First, I recommend accurately measuring the room dimensions, including all window and door positions, using a tape measure and a spirit level to detect any uneven walls. This is crucial because Metod modules should preferably be installed plumb and level.
A solution that is often underestimated, in my opinion, is the installation of wall units or shelving elements mounted on top of the tall cabinets. This way, you can make use of the room height without taking up limited floor space.
It is also important to properly connect and secure the individual cabinets to each other. Using IKEA’s own connector bolts and brackets ensures a stable structure. In tight spaces, I would definitely recommend adjusting the plinths and front panels carefully, as they often accommodate minor slopes that might otherwise cause unsightly gaps.
Regarding assembly: Sometimes it is worth installing the doors before the final installation of the cabinets to work more easily in a confined space.
Have you already measured the narrow spots precisely and maybe taken photos or made drawings that you can describe here? That would allow for more specific advice tailored to your situation.
Pelolo
30 Apr 2022 07:56
Gafiel schrieb:
Have you measured the narrow sections precisely and maybe taken photos or made drawings that you can describe here? That would help address your situation more specifically.
Thank you for the detailed reply and helpful advice. Yes, I have measured the room down to the centimeter, and there are two main problem areas: 1. On the left, a 15 cm (6 inches) wide recess that is nearly 60 cm (24 inches) deep but not completely straight. 2. On the right, the space narrows to about 80 cm (31 inches) in width due to a passageway that cannot be built over.
This doesn’t allow for a continuous front, but I think the 15 cm (6 inches) recess might be used cleverly.
Is it possible to cover or adapt such narrow recesses with Metod cabinets or modular units? Or is it better to avoid this since the depth is only about 60 cm (24 inches) instead of the usual 60 cm? Are there corner solutions designed specifically for narrow or irregular recesses?
Katan
30 Apr 2022 09:18
Pelolo schrieb:
That doesn’t allow for a continuous front, but I think the 15cm (6 inches) niche could be cleverly used.
Absolutely! Small niches are like hidden gems in kitchen planning. If the niche is narrow, you can install open shelves or slightly shallower cabinets that are specifically customized to the height and depth.
Tip: Use internal pull-outs or cabinets with hinged doors and internal compartments to maximize space without blocking the narrow walkway.
Pelolo schrieb:
Are there corner solutions that are specially designed for narrow or irregular niches?
For corners, it’s worth considering a 90° corner carousel if possible. Alternatively, with Metod you can also install angled elements, but that’s a bit more complicated to assemble and requires careful planning. A bit of flexibility during installation is your friend here – with some creativity, a lot can be achieved 😉
RENMA
1 May 2022 14:03
Gafiel schrieb:
Regarding installation: Sometimes it’s worth mounting the doors before installing the cabinets permanently to work more easily in tight spaces.
This is valuable advice, especially in confined areas.
Additionally, I recommend the following measures to optimally adapt Metod cabinet assemblies in tight spaces:
- Planning with an accurately measured room layout: Precise measurements in advance allow for exact consideration of sloped walls, niches, and irregular room sections.
- Avoiding baseboards that stand on the floor and visually reduce space; instead, use flat, adjustable legs.
- Using cabinets without back panels so they can be flexibly adjusted to different wall distances.
- In corners, consider a so-called "blind corner" cabinet to better utilize the potential of the corner.
- Especially with sloped elements, planning should be as precise as possible, since IKEA does not offer standard solutions for every case.
If the structural strength and wall mounting are insufficient, I recommend installing additional wall brackets to securely fix the cabinets and prevent wobbling.
