ᐅ How can I avoid mistakes when assembling Ikea PLATSA?
Created on: 10 Feb 2022 08:23
nicoro
Hello everyone, I am currently assembling my new Ikea Platsa system and would like to learn how to avoid common mistakes during the build. My specific question is: What step-by-step strategies or tools do you recommend to ensure that all parts are positioned and fastened correctly, without having to take everything apart later? Are there particular areas where extra care is needed to minimize assembly errors, for example with the hinges, connectors, or alignment of the modules? Since I already have experience with furniture assembly, I am mainly looking for tips specifically tailored to the PLATSA system rather than general furniture building advice. Thanks for your support!
Kinbu
11 Feb 2022 08:38
nicoro schrieb:
Maybe you have some specific tips for this?
Definitely! If you’re working alone, be sure to plan enough space around the furniture piece so you can move comfortably. – Use aids like spacers or small wooden blocks to hold modules in place when you don’t have a second pair of hands. – Working on the floor and gradually raising the piece can help. – Patience is especially important here; don’t rush assembly steps, as that can easily lead to mistakes.
nicoro schrieb:
whether all connecting pieces really fit together wonderfully easily or if you sometimes have to force or adjust a bit with PLATSA?
Usually, the dowels and connectors fit quite precisely; it’s part of the care to insert them without using force. If it’s sticking, check carefully whether a part is upside down or if a drill hole might be slightly off. Light sanding of edges with sandpaper can help in rare cases.
KIN42
11 Feb 2022 09:05
In addition to the previous tips, I would like to address the topic of screws and torque. When working with Platsa, you should not only follow the correct sequence but also avoid overtightening the screws. This can damage the material and cause microcracks that may reduce stability over time. Use a torque wrench or a cordless screwdriver with a torque limiter if necessary. Before connecting parts, also check the drill holes for any debris or contamination. Additionally, I recommend having an assistant for longer units – even stabilizing the components during assembly helps achieve precise alignment. If you are working alone, make sure the modules rest on stable surfaces to prevent slipping.
