ᐅ How can I install IKEA Platsa units in rental apartments without drilling?
Created on: 31 Oct 2021 18:37
stanleykuS
stanleyku31 Oct 2021 18:37Hello everyone,
I am currently facing the challenge of assembling my IKEA Platsa wardrobe in a rental apartment and securing it firmly without drilling. This is important to me because I don’t want to damage the walls, but the wardrobe also needs to stand securely, especially since the apartment has relatively soft walls (e.g., drywall or thin plaster).
So my question is: How can I fix an IKEA Platsa wardrobe in a rental apartment without drilling, ensuring it stands safely without tipping or wobbling? Are there proven methods that avoid drawbacks such as unstable standing or slipping?
I have already considered clamp systems, heavy floor protectors, and non-slip mats, but I’m unsure if that is sufficient—or if there might be alternative mounting solutions that are non-invasive. I would appreciate any tips or experiences!
stanleyku schrieb:
How can I secure IKEA Platsa units in rental apartments without drilling, so they stand firmly and don’t tip or wobble?Basically, securely fastening large furniture like Platsa requires anchoring that ensures stability and prevents tipping. In rental apartments where drilling is not an option, three main approaches can be distinguished:
- Using furniture clamp holders (such as tip-top fasteners or other pressure-based fittings) to fix units to the wall without drilling holes
- Using heavy anti-slip mats under the feet to prevent sliding
- Connecting multiple Platsa units together for added stability
From experience, clamp holders are the most effective when the wall and the furniture surfaces are compatible. Anti-slip mats alone only prevent sliding but do not provide tipping protection. Connecting multiple modules increases overall stability as well.
It should be noted that some clamp fittings apply pressure to the wall plaster, so caution is advised on very delicate surfaces. An alternative are removable tension systems that work with counterweights, though installation can be more complex.
One more tip: before purchasing, check the wall construction and select products that are designed for the specific surface.
Rodolfo schrieb:
Use of heavy-duty non-slip mats under the feet to prevent slippingThis is an important point. I would like to outline a simple step-by-step method that allows for a secure installation without drilling:
- Step 1: Prepare the wall – clean it thoroughly so that clamp holders or pressure devices can grip securely.
- Step 2: Choose appropriate clamp holders or furniture anchors: opt for products with adjustable pressure to avoid damaging the wall.
- Step 3: Connect multiple modular elements together (e.g., using included fittings) to create a stable assembly.
- Step 4: Place non-slip mats or slip-resistant felt pads under the furniture legs to prevent sliding on smooth floors.
- Step 5: After assembly, check the stability by gently shaking the furniture. If you notice any wobbling, adding an additional clamp holder in the middle can improve safety.
Common mistakes during installation include failing to connect the modules or neglecting the floor surface. On smooth floors, relying solely on non-slip mats under the feet can be risky without additional measures.
In summary: combine wall clamp holders with floor protection – this way, you achieve a relatively stable setup without drilling.
stanleyku schrieb:
Are there proven methods that also avoid disadvantages like unstable stability or slipping?I can fully understand that this point is especially important to you. For me, securing furniture without drilling was also a challenge—not just out of concern for rental damage but also for safety reasons.
After some experimentation, my personal favorite approach emerged:
- Using furniture stop strips attached to the wall with strong adhesive tapes, for example, good-quality double-sided mounting tape.
- Combining these strips with the connection of several Platsa units makes the wardrobe relatively stable.
What helped me the most was adding extra weight: for example, storing materials in the lower section that increase the furniture’s weight, making it less likely to tip over.
I also want to point out that some things can only be figured out by trying them. If you plan to build the wardrobe very tall, I definitely wouldn’t rely solely on adhesive tape but additionally secure it temporarily at the base, for instance, with heavier floor protectors.
It’s definitely a compromise between stability and protecting the rental property, but with patience and testing, you can find a good solution.
