ᐅ How can I secure IKEA Metod cabinets to wooden plank floors?
Created on: 12 Jan 2016 08:37
Songe59
I am facing the challenge of mounting my IKEA Metod kitchen cabinets on an old plank floor. My concern is not only the stability of the cabinets but also protecting the floor from damage and ensuring that the mounting can be removed later without leaving marks.
I have considered using standard plugs and screws but worry that they might cause long-term damage to the plank floor. Are there any special methods or mounting systems that work particularly well on this type of subfloor?
Perhaps someone has had similar experiences or knows effective solutions for securing Metod cabinets safely and gently on plank floors. I would appreciate any detailed suggestions or descriptions of practical steps!
When fastening IKEA Metod cabinets on wooden plank floors, the challenge is to achieve stable fixation without causing mechanical damage to the floorboards. Due to the often delicate wooden planks and their limited material thickness, direct screw fixings into the floor should be avoided.
A three-step approach is recommended:
- First, precisely level the cabinets using the adjustable feet. These distribute the weight evenly and protect the floor.
- Second, prevent slipping by placing felt or rubber pads under the feet.
- Third, fix the cabinets to the wall using appropriate Metod wall brackets or additional brackets. This uses the wall as the primary anchor point without needing to drill into the floor.
If floor fastening is absolutely necessary, special anchors with shallow penetration depth and appropriate screws are required. However, this is recommended only if the plank floor is fully stable and well-secured.
Please also check the cabinet loads and the resulting forces to correctly dimension the fixation.
