ᐅ How can I assemble MALM dressers more securely?
Created on: 20 Sep 2016 09:17
Jonchase
I recently purchased several MALM dressers from IKEA and noticed that, despite assembling them correctly, they still feel a bit wobbly. The overall construction doesn't seem unstable, but especially when I pull out the drawers or there are small vibrations, the dresser noticeably sways.
My question is: How can I make MALM dressers more stable? Are there any special tips or reinforcements that can be used to improve the firmness and overall feel?
I followed the instructions carefully, and all screws are tight, but I'm still not completely satisfied. I’m not looking to completely rebuild the furniture, but small adjustments or simple aids that can be easily applied would be very helpful.
Thanks in advance for your tips!
Jonchase
21 Sep 2016 08:33
I just wanted to share a quick update that I have replaced the back panel with an 8 mm (0.3 inch) MDF board and added a few small angle brackets on the inside edges. The dresser is now much more stable.
I have also experimented with adjustable furniture feet to compensate for minor unevenness in the floor, which further reduced the wobbling.
Thanks for all the great tips so far! For the next assembly, I will definitely tighten the screws again as recommended.
The question remains whether anyone has an idea on how to completely eliminate the wobbling without significantly altering the cabinet?
Meonu
21 Sep 2016 09:02
Maybe placing a thin rubber mat between the dresser and the wall or using specially designed anti-slip pads could help. These reduce movement on the floor and prevent twisting against the wall.
If the drawers are causing the issue, you could try applying a small drop of lubricant to the tracks, in case there is any resistance that contributes to the wobbling.
Sometimes simply fastening the dresser more securely to the wall with special brackets is enough – it’s not a major change and ensures a stable attachment.
kepunau
21 Sep 2016 09:17
With all the tips here, you now have a really rock-solid Malm ready to go! ?
Take a relaxed approach and treat yourself to a coffee while you work; success will follow. And remember: sometimes less is more – don’t rebuild everything, just optimize where it’s really necessary.
I like the combination of brackets, an MDF back panel, and adjustable feet. This way, my cabinet stands rock steady and looks great. Good luck!
