ᐅ How can I assemble MALM beds more securely?
Created on: 20 Dec 2022 09:37
Kar49
I recently assembled a Malm bed from IKEA, but I feel it’s not as stable as I would like. Especially when sitting down or moving around on it more firmly, the frame wobbles slightly, which makes me a bit uneasy. I have already made sure to tighten all the screws securely, but I’m not sure if there are any assembly tips or adjustments that could significantly improve its stability.
How have you made your Malm bed more stable? Are there any special tips or tricks, such as particular screw techniques, additional parts, or assembly methods? I would appreciate any advice on how to get the bed to stand firmly and safely without constantly worrying that something might give way.
Thank you in advance for your suggestions!
Kar49
20 Dec 2022 12:27
SauDietmar schrieb:
At the points where the side panels connect with the headboard and footboard, you can install small metal brackets (available at hardware stores) for reinforcement – this makes a huge difference.
Thank you, that sounds interesting. I wouldn’t have thought it was possible to retrofit the joints with metal brackets without changing the appearance of the furniture too much. What is the best way to attach the metal brackets so that they are not visible or at least minimally noticeable? Are standard screws from a hardware store sufficient?
I also imagine the wood on the bed might be quite thin – is that a problem when installing brackets? What dimensions would you recommend?
SauDietmar
20 Dec 2022 13:01
The metal brackets I use are angle profiles measuring about 40x40 mm (1.6x1.6 inches) with a thickness of 2-3 mm (0.08-0.12 inches). The screws should be short and have a diameter of 3-4 mm (0.12-0.16 inches) to avoid splitting the wood. Pre-drilling is absolutely essential to prevent the chipboard from cracking.
To position the brackets so they are barely visible, I usually mount them on the inside of the bed sides, at the joint between the headboard/footboard and the side panel. Since these areas are often only visible from the inside (under the slatted frame), it is hardly noticeable.
If necessary, you can also choose small brackets that sit flat against the surface so they do not get in the way.
If you want the brackets to be even less visible, you can paint them to match the wood or even cover them with small wooden trims.
Tip: Use a cordless drill with a torque limiter and insert the screws carefully, step by step. This helps prevent damage to the material.
If you like, I can provide exact sources for suitable brackets.
Kar49
20 Dec 2022 13:15
A small addition from me, in case it’s helpful:
Sometimes the reason for wobbling is that the drilled holes in the material have expanded due to overtightening, so the screws no longer grip properly. In this case, applying the appropriate wood glue to the screws or filling the holes with wood filler material can help—then restore the dowel holes and reattach the screws.
This may be a bit time-consuming, but if the bed is frequently used, the investment is worthwhile for long-term stability.
sarlo
20 Dec 2022 13:42
Hello Kar49,
I can imagine you’re wondering how to improve the stability of your Malm bed. I have the same type of bed myself, and there are a few things I always pay attention to:
First of all, it’s really important that all screws are tightened securely. Over time, they tend to loosen from getting in and out of bed. I regularly check and tighten them when necessary.
It also helps to assemble the frame completely parallel and level – even small crooked angles can cause wobbling. You can also treat the material a bit, for example with a protective varnish that makes the wood a little more stable.
If you still have issues, you can install wooden strips inside critical connection points to add extra stability. These strips should be well glued and screwed firmly in place.
I hope these tips are helpful for you.
Kar49
20 Dec 2022 14:11
sarlo schrieb:
If you still have issues, you can install wooden battens on the inside at critical joints to add extra stability.
Thanks for the tip about the wooden battens! What dimensions would you roughly recommend for such a batten, and what is the best way to attach it?
Is it also possible to use plywood or solid wood for this, or would that be too heavy for a MALM bed? My goal is to make the whole structure as sturdy as possible without much visible effort or making the bed too heavy.
Dilen
21 Dec 2022 08:22
Good morning, Kar49.
I like to reinforce the scaffolding with wooden battens at the corner joints. A common approach is to use battens about 20-30 mm (0.8–1.2 inches) wide and 10-15 mm (0.4–0.6 inches) thick, which are screwed and glued at a right angle to the side panels as well as the end panels. This adds extra lateral rigidity.
Plywood is excellent for this purpose because it offers high stability while remaining relatively lightweight. Solid wood is stable as well but can be unnecessarily heavy and may cause pressure marks on the floor.
In general, I recommend:
- Cutting the battens precisely
- Pre-drilling the screw holes
- Using wood glue and screws together
- Neatly rounding off or trimming any protruding batten edges to avoid them sticking out
If you like, I can sketch a detailed construction plan or provide more tips on cutting.
If you have any questions, feel free to ask!
