ᐅ How can I assemble Ikea Metod cabinets using minimal tools?
Created on: 26 Apr 2023 08:17
Robo5
Hello everyone, I am currently planning to assemble IKEA Metod cabinets but have a very limited set of tools available. My question is: How can I assemble IKEA Metod cabinets using as little tooling as possible, without compromising on stability? I only have a cordless drill, a screwdriver, and a hammer. Many of the instructions rely on various specialized tools or helpers, which I do not have. Are there any tips or special tricks to make the assembly as efficient and low-tool as possible? Thanks!
Repar
27 Apr 2023 07:12
If a hammer is not available, a sturdy, flat piece of wood or an old book can help to gently adjust delicate parts without damaging tools.
Ellis
27 Apr 2023 10:03
It is also important to strictly follow the order in the instructions. If you assemble the components incorrectly along the way, tool shortages can become an even bigger problem. Patience pays off.
koduga
27 Apr 2023 14:29
Ellis schrieb:
It is also important to strictly follow the sequence in the instructions.
Exactly, I think this helps prevent frustration, which often occurs when you start without fully equipped tools.
TARAON
28 Apr 2023 09:17
I have to say, using minimal tools makes the process a bit more challenging, but definitely doable! You shouldn’t lose the enjoyment of building, otherwise it becomes a nightmare. My tip: keep a small, sturdy ruler and a pencil handy alongside your cordless screwdriver. Often, that’s enough to align everything precisely and mark small points before inserting screws. This way, you work more accurately and can avoid mistakes.
Fitigu
28 Apr 2023 10:43
TARAON schrieb:
Keep a small, sturdy ruler and a pencil ready alongside the cordless screwdriver.
Precise alignment prevents problems later on, that is correct. Additionally, especially with large cabinets, be careful when fitting the individual modules together – support or a stable surface is advisable here.
DEOLAU
28 Apr 2023 16:00
One more tip: Use some wood glue for the dowels, if the cabinet allows. This increases stability and does not require any additional tools.
