ᐅ How can I assemble Ikea Brimnes furniture myself without professional assistance?
Created on: 8 Jun 2017 14:23
Roboon
Roboon
8 Jun 2017 14:23
I am about to purchase some Ikea Brimnes furniture, but I have a small issue: I want to assemble it myself because I prefer to be independent of professional assembly services and see it as a challenge. However, I am wondering how to best approach this if I don’t want to hire professional help and might not have an extra person to assist.
Specifically, I am interested in how to sort the individual parts most effectively, which tools are necessary, and if there are any particular tips or tricks that can make the assembly significantly easier—especially since the instructions sometimes seem quite complicated. Are there recommended sequences or techniques for Ikea Brimnes that one should know to avoid frustration?
I look forward to your experiences and advice on how to assemble Brimnes furniture as smoothly as possible on my own at home.
Pome60
8 Jun 2017 15:48
Hey Roboon,
that sounds like a really exciting project! I’m sure you can do it! 🙌
A few tips that always help me:
- Definitely take some time and stay calm in the morning so you’re not rushed.
- Lay out all the parts neatly on the floor first; this way you can immediately see if everything is there.
- Read the instructions step by step – and pay close attention to how the parts fit together. Take your time with this!
- When screwing parts together, it often helps to loosely fix all parts first and then tighten them properly at the end. This way you can still adjust if something doesn’t fit quite right.
The most important thing: stay relaxed and enjoy the process! It can be stressful sometimes, but it’s really rewarding when the piece of furniture is finally complete. 😊 Good luck!
klo40
9 Jun 2017 08:36
Pome60 schrieb:
Make sure to take your time and stay calm in the morning so you don’t feel rushed.
Exactly, that’s a very good point. I’ll add a brief step-by-step guide on how you can proceed systematically:
- Step 1: Sort all components and screws, and check that nothing is missing. This will help you avoid unpleasant surprises later.
- Step 2: Prepare your tools – for Brimnes you usually only need the included Allen wrench and a Phillips screwdriver. A small hammer might be useful if some wooden dowels get slightly stuck.
- Step 3: Read the entire instruction manual to get an overview of the process. Sometimes this helps you quickly understand important connections.
- Step 4: When working with parts that involve metal brackets or rails (e.g., drawer slides), make sure to install them slowly and precisely so everything runs smoothly afterward.
- Step 5: Assemble most parts flat on the floor before standing them up – this protects your back and is easier overall.
If you’re working alone, it’s also helpful to protect heavy parts from scratches by placing a blanket or cushions underneath when rotating or moving them on the floor.
One more tip: Brimnes furniture is sensitive to overtightening screws, so work gently to avoid marks or damage.
Good luck with the assembly!
MUMEO
10 Jun 2017 11:17
Roboon schrieb:
Are there any specific sequences or tricks for IKEA Brimnes that one should know to avoid frustration?
I can say that the order is indeed crucial, especially for larger cabinets in the Brimnes series. It’s recommended to assemble the main frame completely first, without immediately fixing the back panel. This way, you can still make adjustments when installing shelves, rails, and doors if needed.
Then attach the back panel, which provides the necessary stability. If you fix the back panel too early, it’s difficult to make any corrections afterward.
Small helpers like a magnetic strip for screws or even small clip boxes can also be very useful to keep things organized during assembly.
It’s also important not to rush and to regularly check the alignment along the visible edges, otherwise doors and drawers may stick.
I hope this helps!
