ᐅ How can I assemble IKEA Besta furniture so that it remains stable and durable over the years?
Created on: 5 Jun 2020 14:23
Peoclemens
Peoclemens
5 Jun 2020 14:23
Hello everyone, I am planning to assemble an IKEA Besta shelving unit, but I am concerned about whether it will remain stable and not wobble or warp after several years of use.
My question is: How can the IKEA Besta be assembled and, if necessary, reinforced to ensure it stays stable even after years of use and load?
I have noticed that IKEA’s instructions are quite basic, but I am looking for tips on proper handling of the components, additional reinforcements, assembly advice, or any special tricks for wall mounting.
I intend to build the unit as tall as possible (around 2m (6.5 ft)) with several compartments as a sideboard, and I want to avoid instability over time, especially when it is loaded.
Thank you for your experiences and professional tips!
dunitan
5 Jun 2020 14:57
Hello Peoclemens,
you have raised a very relevant question that concerns many owners of IKEA Besta shelving units. In general, the Besta system is designed to remain stable under normal use – but there are a few important points you should keep in mind if you want long-term stability.
First and foremost, securing the unit to the wall is crucial, especially for tall cabinets over 2m (6.5 ft). Many people underestimate how much the furniture can wobble due to loading and movement. Use the supplied wall anchors and, if possible, add extra screws into the wall (e.g., heavy-duty anchors for concrete or sturdy wood screws for solid wood).
Also, during assembly, make sure all connections (screws, dowels) are tightened as firmly as possible without damaging the material. Pay particular attention to the shelves and side panels, which should have no gaps to ensure even load distribution.
For additional reinforcement, you can strengthen the unit internally with metal brackets if you feel comfortable with screwing them in. Sometimes, a bottom panel or a thick back panel can also help stabilize the cabinet further.
If you plan to store heavy items, I recommend distributing the weight evenly and using the lower compartments primarily.
I hope these tips help you! If you like, I can also provide a brief overview of suitable types of anchors and screws.
lalutau
5 Jun 2020 16:03
Hello Peoclemens,
you specifically asked about stability-enhancing measures for IKEA Besta. Based on my experience and research, the stability can be improved as follows:
- Fixing the unit to a solid wall is mandatory. This prevents tipping accidents and reduces stress on the furniture.
- Use wooden or metal brackets for reinforcement inside. For taller units, a cross brace in the middle is especially recommended.
- The supplied back panel made of thin particleboard is mainly for appearance but also contributes to stability. Make sure it is installed flat and fully.
- Use high-quality screws and wall plugs suitable for the wall substrate: for example, metal anchors for concrete, cavity anchors for drywall.
- Shelves should not be overloaded, as they may bend under excessive weight. In some cases, adding support strips underneath the shelves can help.
Finally, the unit should not stand loosely but be fixed directly to the wall to prevent any movement during use.
If you can provide more details about the floor conditions or wall materials, I can give you more precise recommendations.
LANICOLE
6 Jun 2020 10:17
Hello Peoclemens,
to keep your IKEA Besta stable and durable for many years, I want to provide you with a structured guide that combines basic and advanced tips:
1. Preparation:
- Before starting assembly, check if the floor is level. Uneven floors can make the entire piece unstable. If necessary, adjust using felt or rubber pads.
2. Wall Attachment:
- This step is absolutely essential: use the provided fixings plus additional screws and anchors that match your wall material.
- For drywall (plasterboard) walls, specialized cavity anchors are just as important as appropriately sized brackets.
3. Assembly Steps:
- Tighten all screws on the side panels and connecting parts by hand first before fully tightening them. This prevents warping.
- Check right angles with a square — shelves that twist slightly during assembly will be unstable later.
4. Stabilization:
- Always install the back panel as intended. It provides significant lateral reinforcement.
- For particularly tall or wide units, additional metal angle brackets can be attached inside the back for extra support.
5. Load:
- Heavy items should ideally be stored on lower shelves to keep the center of gravity low.
- Avoid point loads in the middle of shelves by supporting them with wooden battens.
6. Rechecking:
- After six months and then annually, retighten all connections, since the wood can develop slight movement over time.
Summary: Precise assembly, consistent wall mounting, and regular maintenance are key to the long-term stability of the Besta.
If you have specific questions about any of the steps, I’m happy to help.
