ᐅ How can I precisely level Ikea Metod cabinets on uneven floors?
Created on: 10 Jan 2023 08:17
NEOPOHello everyone,
I am planning to install my Ikea Metod kitchen cabinets in an older apartment with a very uneven floor, aiming for millimeter-precise alignment. Since the Metod cabinets come with height-adjustable legs by default, I am wondering how to adjust them on significant unevenness so that the fronts end up perfectly straight and aligned.
I want to avoid doors sticking when closing or visible gaps. So far, I have considered using a spirit level and adjusting each leg individually, but I am wondering if there are more precise methods, especially since the height differences can be up to 2cm (0.8 inches) in some areas.
Are there any tools or procedures you would recommend that go beyond simply adjusting the legs? Maybe special shims, wedges, or adjustment mechanisms that can be used as supplements?
I appreciate any tips that can help achieve perfect alignment of Ikea Metod cabinets on such uneven floors without making the assembly overly complicated.
Interesting question.
This is indeed a core issue with uneven floors. Precise alignment to the millimeter usually requires a combination of accurate measurement, high-quality tools, and above all, a systematic approach.
My advice would be to start with a detailed survey of the floor, ideally using a laser level to record height differences at several relevant points. Based on this, you can then adjust the cabinet feet accordingly.
However, the factory height adjustment of Metod feet, around 8 cm (3 inches), is usually only sufficient for minor unevenness. With a 2 cm (0.8 inch) difference, you should consider using sturdy wedges or special shims made of metal or wood to compensate for the inconsistent foot heights.
Compared to simple wooden wedges, adjustable shims are more precise and stable, preventing later deformation or slipping.
Also, remember to screw the cabinets to each other sufficiently to maintain alignment. Otherwise, each cabinet stands alone and may shift under load.
NEOPO schrieb:
I want to avoid doors sticking when closing or visible gaps appearing.
I would like to add that when dealing with uneven floors, using a spirit level for precise work is useful but has its limits, especially when the differences exceed 1 cm (0.4 inches).
You can also place the cabinets on thick, self-cut wooden boards that are precisely adjusted after measuring the floor. This creates a new, level base. It is important that the substructure is absolutely stable and even so that nothing shifts or wobbles over time.
For the individual feet, I often use so-called furniture height adjusters with a knurled nut, which can be set more precisely than the original IKEA feet. These cost extra per piece but are worth it for large height differences.
Additionally, I recommend connecting the cabinets to each other with screws to keep the entire kitchen run rigid and stable – this relieves the feet and ensures long-lasting stability.
For more precise alignment to the nearest millimeter when installing Ikea Metod cabinets on uneven floors, I recommend the following structured approach:
- First, measure the floor height at several points (at least 3-4 measurement spots per cabinet) using a laser level or a precise spirit level and record the heights.
- Use high-quality, finely adjustable furniture leveling screws or adjustable feet components for decimal adjustment of the height, which perform better than Ikea’s standard feet.
- For floor unevenness over approximately 15 mm (0.6 inches), use additional shims (e.g., ceramic-coated MDF boards or aluminum plates) available in various thicknesses to accurately adjust the height.
- Always screw the cabinets together to ensure an even distribution of loads.
- Finally, adjust all cabinet doors (height, lateral offset, angle) to compensate for any minor irregularities.
This method will achieve millimeter-precise alignment that remains stable over time.
Hey NEOPO,
I had exactly the same problem! 😊 For me, the combination of precise floor leveling with a laser and the use of homemade wooden wedges as spacers worked really well. I made the wedges by skillfully stacking thin plywood strips on top of each other, which allowed me to finely adjust the height.
It was also important for me to connect the cabinets together because that way, none of them would wobble individually.
And honestly, I really enjoyed the leveling process because in the end, I saw the perfect result! So: don’t hesitate, take your time, and don’t lose motivation – it’s definitely worth it! 🙌
