Hello everyone, I have a somewhat unusual question about my IKEA Billy shelves: How exactly can I adjust the height of the individual shelves once the unit is already assembled? I want to use the compartments more flexibly and store some taller items there. Is there a way to change the shelf heights afterward without compromising the stability of the unit or causing the holes to wear out too much? I would appreciate a detailed explanation or practical tips, as I don’t want to completely rebuild the shelf. Thanks in advance!
Adjusting the height of the shelves in a Billy bookcase is generally intended and is done using the small shelf supports that fit into the holes on the inside corner of the side panels.
1. Remove the shelf: To move a shelf, carefully take it out.
2. Move the supports: Remove the shelf supports from the current holes and insert them into the desired new holes.
3. Replace the shelf: Place the shelf back onto the repositioned supports.
Make sure the supports are fully and securely inserted. The holes are spaced at 32 mm (1.26 inches) intervals, allowing for flexible shelf heights. Frequent adjustments may cause wear over time, which can reduce the stability of the unit. However, occasional repositioning should not cause any issues.
baAlejandr14 Dec 2022 10:46draleo schrieb:
The holes are standardized at intervals of 32 mm (1.26 inches), allowing for adjustable heights.That is correct. Additionally, if the shelf is already set to the maximum height options available from the existing holes, you cannot simply insert a custom height in between. However, if you have experience in furniture-making, you can use DIY wooden strips or drill additional holes in suitable locations.
But in general, adjusting the supplied brackets is sufficient.
I would like to provide a step-by-step guide on how to properly adjust the shelf heights in Billy bookcases and avoid common mistakes:
1. Open the shelf from the top or hold the side panels securely.
2. Carefully lift and remove the shelf—do not pull with force, as this can enlarge the holes.
3. Remove the shelf supports (small plastic or metal clips).
4. Choose a new position for the supports—the holes are spaced at 32mm (1.25 inches) intervals.
5. Fully press in the supports so they sit firmly.
6. Place the shelf back on and check the position.
It is important not to repeatedly use the same drill holes, as this causes wear. If the holes are worn out, small wooden shims or replacement supports can help.
