ᐅ How can I adjust the door hinges on the Pax wardrobe?
Created on: 8 Mar 2018 09:13
pedeo
pedeo
8 Mar 2018 09:13
I have a Pax wardrobe from Ikea and have noticed that the doors are increasingly difficult to align properly. Specifically, it’s about the door hinges: after some time, they don’t seem to sit exactly right, which causes the doors to no longer close flush or results in slight gaps.
I am interested in how to best readjust the door hinges on the Pax furniture to realign the doors perfectly. Are there specific screws that need to be adjusted for this? Do I need special tools or particular techniques? What is the recommended sequence to avoid causing further issues?
I would appreciate a detailed step-by-step guide, as I want to solve the problem myself without having to call a professional right away. Thank you in advance!
bauku
8 Mar 2018 10:47
Hey pedeo!
Great that you want to tackle this yourself! 😃 With Pax hinges, you can usually make three adjustments using a Phillips screwdriver:
- Depth adjustment (to move the door forward or backward)
- Height adjustment (to raise or lower the door slightly)
- Side adjustment (to align the door horizontally)
Start with the side adjustment, then the height, and finally the depth. Very important: make only small adjustments at a time and test the door in between!
And don’t worry, you’ll do great—fingers crossed! 💪
cassandra
8 Mar 2018 11:52
Additional information:
The door hinges of the Ikea Pax system offer three-dimensional adjustment, usually achieved by turning specific screws:
- Lateral adjustment is done via a screw on the side of the hinge and controls the distance to the cabinet wall.
- Height adjustment is typically possible through screws on the hinge head or the mounting plate, ideal for finely tuning the vertical position of the door.
- Depth adjustment moves the door closer to or further away from the cabinet.
My tip: Before making any adjustments, check the hinge fittings and slightly tighten all screws to prevent twisting during adjustment. Work systematically from top to bottom. After each adjustment, close the door and check if the gap is even.
No special tools are needed; a Phillips screwdriver is usually sufficient.
baelku
9 Mar 2018 08:37
cassandra schrieb:
No special tools are needed; usually, a Phillips screwdriver is enough.
Exactly, a simple Phillips screwdriver will do.
First, turn the screw for the lateral adjustment, then adjust the height. The depth adjustment is usually the smaller screw at the front of the hinge.
Make only small adjustments at a time; otherwise, the doors may no longer fit properly. Check after each change.
kaflo8
9 Mar 2018 13:26
pedeo schrieb:
I’m interested in how to best adjust the door hinges on the Pax furniture to realign the doors perfectly.
When adjusting the Pax door hinges, it is best to follow a structured approach:
- Open the door and locate the three adjustment screws on the hinge.
- The screw for lateral adjustment allows you to move the door horizontally.
- The height adjustment lets you shift the door vertically, which is important for doors that are misaligned vertically.
- The depth adjustment controls the gap between the door and the cabinet front.
A Phillips screwdriver size PH2 is usually the required tool.
Important: Adjust only one screw at a time and check the door alignment by closing the door after each adjustment. If the doors do not stay properly aligned, also check the hinge mounting and the stability of the furniture.
