ᐅ How can I adjust Malm drawers more easily?
Created on: 27 Dec 2020 14:07
KIANKLO
KIANKLO
27 Dec 2020 14:07
I am currently looking into how to adjust the Malm drawers from IKEA more easily. Sometimes they stick slightly or don’t slide smoothly. I suspect the issue is related to the correct alignment of the drawer on the runners or guide rails.
My main question is: Is there a precise method to adjust Malm drawers so they operate smoothly and effortlessly without wobbling or sticking?
Any tips on accurately adjusting the screws or a guide for fine-tuning the rollers would be very helpful. I have already tried carefully loosening and retightening the screws, but the results have not been consistently satisfactory.
Looking forward to your experiences and advice!
JAPLO
27 Dec 2020 16:23
Hello KIANKLO,
your description clearly reflects the common issue with Malm drawers. The solution lies in the precise adjustment of the drawer slides, specifically the side screws that attach the slides to the drawer.
I recommend the following steps:
1. Fully pull out the drawer and lift it to remove it from the slides.
2. Slightly loosen the screws on the slides attached to the drawer using a Phillips screwdriver.
3. Adjust the slide horizontally in small increments (about 1-2mm (0.04-0.08 inches)) to ensure the drawer moves straight when opening and closing.
4. The height can also be fine-tuned by adjusting the rear screws on the drawer, which helps prevent jamming.
It is important to retighten the screws securely and then carefully open and close the drawer multiple times to check the result. This way, you can gradually find the optimal position. It is helpful if you apply light pressure when adjusting the drawer while someone else moves it.
If the slides are dirty, I recommend cleaning them before making adjustments and, if needed, applying a little WD-40 or silicone oil to the slides. This also improves the smoothness of operation.
This should help you achieve better and easier drawer movement.
barda6
28 Dec 2020 08:14
JAPLO schrieb:
It is important to tighten the screws again and then carefully slide the drawer in and out several times
Exactly. I often use small felt strips on the sides if the drawer wobbles.
Also, check the drawer slides for any debris.
RENMA
29 Dec 2020 11:52
Additional Information:
The Malm drawers use side-mounted drawer slides with an adjustment mechanism that allows precise positioning using screws. This adjustment typically involves three dimensions:
- Horizontal (side-to-side movement)
- Vertical (drawer height)
- Depth (forward and backward positioning)
Usually, two screws are used on the slide rail – one for fixing, the other for fine adjustment via a sliding mechanism.
My recommendation:
1. Fully extend the drawer and carefully detach it from the slides by releasing the latches or clips.
2. First, adjust the height by turning the screw at the back of the slide rail, as this is often the main cause of binding.
3. Then adjust the horizontal alignment using the side screws.
4. Reinstall the drawer and test its movement.
Important: If binding occurs again despite adjustments, check whether the slides are securely attached and whether there are any deformations or foreign objects present.
Finally, regular cleaning and lubrication with suitable products ensure smoother operation. Avoid using oils that attract dust; instead, use silicone-based lubricants.
Proper adjustment requires some patience, but the steps are relatively simple if approached systematically.
