Hello everyone, I am currently planning to install an Ikea Pax wardrobe in a room with a sloped ceiling. My question is how to best adapt the wardrobe to the angled wall without having to do a lot of cutting myself, while still achieving a stable and visually appealing solution. Specifically, I am interested in any methods or tricks you know to fit the Pax system neatly into attic or loft rooms – for example, special cabinet systems, different door installation options, or the use of existing accessories. I want to find a practical approach to optimize storage space without it looking like a makeshift or half-finished solution. Has anyone had experience with sloped ceilings and Pax, or can offer tips for adjustments? Thanks in advance!
When adapting Ikea Pax wardrobes for sloped ceilings, careful planning is essential. In my experience, there are two main approaches: either you use standard Pax carcasses and adjust the slope with custom-made covers or panels, or you cut the carcasses individually – the latter requires some DIY skills.
- A popular solution is to use carcasses without back panels in the sloped area and install custom shelves or storage units there.
- Doors or sliding doors can be specially trimmed, or you can use smaller modules to compensate for the slope.
- Additionally, Ikea’s accessories include suitable baseboards or corner panels that you can use to neatly cover the transitions.
My advice: Take precise measurements at several points along the slope, as even small deviations can disrupt the planning.
narDietmar10 Jan 2023 13:22PULAU schrieb:
Either you build with standard Pax carcasses and adjust them to the slope using custom-made covers or panels, or you cut the carcasses individually.Exactly, the combination of standard modules and custom adjustments is usually the most practical solution. For the roof slope, I now recommend installing sturdy angle profiles in front of the wall to serve as guides or support surfaces for the cabinet carcasses, especially if the slope is very steep.
- Alternatively, I have worked with double-sided cabinets whose backs are also fitted with perfectly matching panels to fit the slope.
- If you use sliding doors, make sure the track rails are precisely aligned to prevent the doors from sticking.
Ultimately, it is important to choose a flexible approach to allow fine-tuning adjustments during on-site assembly.
I can understand well that dealing with a sloped ceiling and Pax wardrobes can be frustrating. I faced a similar challenge and took plenty of time to find a fitting solution. The important thing is not to stress too much and to allow yourself some creative approaches.
Sometimes it helps to work with open Pax frames and only trim the front panel at the top where the slope is. I didn’t buy anything special for my slope but used old wood scraps as covers, which I sanded to fit properly.
If you’re not very skilled with DIY, I would recommend getting help at least for the cutting tasks. But don’t worry – with a bit of patience, it can even be enjoyable to design the wardrobe so that it truly fits.
SANMAR schrieb:
Sometimes it helps to simply work with open Pax frames and only trim the front top to fit the slope.Exactly, sometimes less is more! 🙂
I just built my closet a bit shorter and filled the space between the slope and the top edge with some decorative baskets. It not only looks good but also allows some breathing room and creates a unique visual effect.
With a pitched roof, I wouldn’t fill every space with complicated cuts – a little breathing room and some humor help a lot 😉
