I noticed that some doors on my new Ikea Metod kitchen unit have slightly warped or don’t close flush. I assume the Metod doors can be individually adjusted to ensure a perfect fit and alignment. My specific question is: How can I adjust the Ikea Metod doors myself to correct uneven gaps or sagging doors? Which screws exactly do I need to turn, in which direction, and are there any important things to keep in mind to make sure the door stays stable and securely in the new position after adjustment? I have tried some adjustments back and forth but am unsure if I might cause damage. I would really appreciate detailed instructions or tips!
Hello fologi,
Regarding your question on how to adjust Ikea Metod doors yourself, here is a detailed step-by-step guide:
- Each Metod door has three adjustment screws on the hinges:
- One screw adjusts the height (up and down).
- Another screw controls the depth (bringing the door closer to or further from the cabinet body).
- The third screw sets the lateral position (left/right).
- To adjust the height, slightly loosen or tighten the screw located above or below the hinge pin. This is especially helpful if the door is hanging unevenly.
- For lateral adjustment, turn the small screw on the hinge arm to ensure even gaps between the doors.
- The depth adjustment is done by turning the screw at the very front of the hinge arm, so the door aligns flush with the cabinet body.
Important: Always make very small adjustments and check the effect after each turn to avoid damaging the hinge or door.
When adjusting multiple doors, finish adjusting one door completely before moving on to the next. This approach gives the best results.
Hope this helps! If you want, I can also send you more detailed information about the exact screw positions.
Hello fologi,
I would like to add some information to make the adjustment of Ikea Metod doors really understandable and precise. Metod cabinets usually have clip-on hinges that can be adjusted in three dimensions:
1. Lateral adjustment (left/right): The small adjustment screw, usually located on the top of the hinge arm, moves the door horizontally. Turning the screw to the right shifts the door accordingly, allowing you to adjust the gap sizes.
2. Height adjustment: This is typically done via two screws on the back of the hinge, which move the hinge pin up or down. Sometimes these are protected by a cover cap that you should gently remove.
3. Depth adjustment: At the front of the hinge arm, there is a screw that you can turn in or out to bring the door closer to or further away from the cabinet body.
An important tip: Especially with new kitchens, doors might still be slightly misaligned, which is normal. Also, the material (wood, MDF, lacquer) reacts to humidity, so small adjustments may be necessary over time.
Additionally, after adjusting, always check that the door closes smoothly—if there is resistance or parts scrape, the depth and height adjustments should be reviewed and fine-tuned.
One small question: What type of door panel do you have (glass, lacquered, wood)? This can affect stability and adjustment, as some materials are heavier and may require different hinges.
Filippo schrieb:
One more quick question: What type of door panel do you have (glass, painted, wood)? This can affect stability and adjustment since some materials are heavier and require different hinges.That’s a very good point! Extra weight from glass or wooden doors does indeed matter. For glass fronts, it’s often worth checking the hinges from time to time to ensure they’re tight, as screws tend to loosen due to the weight and frequent opening cycles.
Another tip: If you’re unsure, always adjust the hinges with a properly fitting screwdriver. A stripped screw head can quickly damage the hinges.
Also, if the doors are very difficult to adjust, sometimes it helps to remove the door to access the screws more easily. Be careful when doing this and watch out for the clips, which are often simple but delicate.
Hello fologi,
I’d like to add to the points mentioned so far with a clearly structured quick guide for self-adjusting your Metod doors. This way, you can proceed systematically:
- Step 1: Check the door by hand. Which side protrudes? Where are the uneven gaps?
- Step 2: Carefully lift the door and unhook it from the hinges, if possible, to more easily access all screws.
- Step 3: Adjust the depth: turn the screw at the front of the hinge arm (usually clockwise to bring the door closer to the cabinet).
- Step 4: Adjust the lateral position (left/right): regulate the small screw at the top of the hinge arm with small turns in the required direction.
- Step 5: Adjust the height: turn the screw at the back of the hinge in small increments until the door hangs flush.
- Step 6: Rehang the door and check whether all gaps are even and the door closes smoothly.
Common mistakes:
- Turning screws too roughly or too quickly
- Over-tightening screws and damaging the hinge
- Insufficient checking after each adjustment
One final tip: For troublesome areas, it’s worth using a spirit level to precisely check vertical and horizontal alignment.
I hope this helps you. Good luck!
Common mistakes:
fologi schrieb:
How can I adjust the Ikea Metod doors myself to fix uneven gaps or sagging doors?In short: Use the three screws on the hinge for height, depth, and lateral adjustment. Turn them carefully with the appropriate screwdriver to align the door. Raise the door if it’s sagging, shift it sideways for even gaps, and adjust the depth so the door closes flush with the cabinet frame.
Make small adjustments step by step rather than large ones to avoid damage.
