Hello everyone, I recently assembled some IKEA Metod kitchen cabinets, and I noticed that some doors are not properly aligned and close unevenly. My question is: How can I adjust IKEA Metod cabinets myself to level the doors precisely and achieve optimal gaps? Are there any tips regarding the hinges or adjustment screws that I should be aware of? I suspect that a specific sequence and procedure, possibly with special tools, might be helpful. I’m looking forward to practical advice from you, especially which steps are most important to avoid visible gaps or sagging doors.
Bakate schrieb:
I suspect that a certain order and approach, maybe with special tools, can be helpful.Definitely! It really helped me to roughly position all the doors first. Then fine-tune them, starting with adjusting the height, followed by aligning them sideways, and finally setting the hinge depth. I wouldn’t use a cordless drill for this; a small screwdriver is better for more precise control. Always make small adjustments, otherwise the door can quickly be misaligned. It’s not always fun, but after adjusting, the kitchen really looks great!
SAWYERR schrieb:
It’s best to use a small screwdriver and make adjustments in small increments.I can only laugh about the small screwdriver – I initially tried with too much force, and that just caused everything to jam. Patience is key, and having a coffee nearby makes the fine-tuning much more enjoyable.
Danial schrieb:
Are there any experiences on how to avoid or improve the more problematic hinge system?It is possible to install alternative hinges, but this requires modifications to the cabinet structure, which IKEA typically does not intend. In my opinion, the original adjustment is sufficient if done carefully. Simply use the three adjustment screws patiently and precisely, and it usually works fine.
