I noticed that the doors on my IKEA Billy bookshelf do not close properly. They stick in some places or leave a slight gap, even though I have adjusted the hinges multiple times. I would like to ask how to precisely adjust the Billy doors so that they close flush and smoothly without resistance. Are there specific steps or tools that I should be aware of? I am also interested in whether the material might be affected by moisture or expansion. Thanks for your tips and experiences!
Tiren70 schrieb:
Is there any effect from removing the doors that improves the accuracy of the adjustment?Yes, that actually makes sense. When you take the doors off their hinges, you have more room to work and can adjust each screw much more precisely without the door shifting due to its own weight or moving even slightly.
My suggestion for the optimal procedure:
- Remove the doors: Most Billy hinges have a small lever or release mechanism to easily take off the door.
- Then use a screwdriver to adjust all three adjustment screws step by step.
- You can also place the door on a flat surface to check if it is warped.
- Afterwards, screw the hinges back on, rehang the doors, and check the gaps and closing movement.
Even if this sounds a bit more involved at first, it is the most effective way in the long run to set the doors cleanly and maintain perfect alignment.
Jensson schrieb:
Remove the doors and adjust the screws step by stepHere is a precise approach:
- Start with the vertical adjustment by tuning the hinges attached to the cabinet.
- Next, adjust the lateral screw to achieve even gaps and avoid any contact points.
- Finally, adjust the depth so the door fits flush without pressing against the frame.
Avoid overtightening the screws, as frequent adjustments could damage the mechanism.
If the material is an issue (wood movement), maintaining a controlled environment with stable humidity is recommended.
Additionally, if problems occur often, consider replacing the hinges (e.g., high-quality soft-close hinges) that offer more adjustment options.
These are practical steps and options for long-lasting solutions.
