ᐅ How can I add handles to IKEA PLATSA doors afterwards?
Created on: 22 Aug 2023 09:37
Tugajan
Tugajan
22 Aug 2023 09:37
I bought some IKEA Platsa cabinets that come standard with handleless doors. Now I want to add handles to these doors later to make them easier to use and to enhance the overall look a bit. However, I’m not sure about the best way to do this without damaging the doors or affecting their appearance.
I’m especially interested in tips on the following points:
- What type of handles work best with PLATSA doors?
- How can I attach handles when the doors don’t have pre-drilled holes?
- Are there specific drilling techniques or tools to avoid damaging the material?
- Does anyone know of alternatives to traditional handles that are still practical and sturdy?
I look forward to your experiences and recommendations. Thank you in advance!
kaubi
22 Aug 2023 11:05
Hello Tugajan,
I can understand your concern, as retrofitting handles on IKEA PLATSA doors generally requires a careful approach to maintain the high-quality appearance and functionality of the doors.
First, you should know that PLATSA doors are often made of coated MDF or particleboard. Drilling through them is usually straightforward if done correctly, but dull drill bits or incorrect angles can easily cause chipping. I would recommend using a sharp 3-4 mm (1/8–5/32 inch) wood drill bit—ideally a Forstner bit or a special drill bit designed for coated panels.
Regarding handle options, there are basically two types:
- Recessed handles: These are usually fitted without drilling holes and are recommended if you want to avoid drilling. However, they are less common for PLATSA doors.
- Surface-mounted handles: These include traditional bar handles or slim handle bars. It’s important to carefully measure and mark the handle positions before drilling.
It’s practical to start the holes with a small center drill and then drill precisely with the correct diameter bit. To protect the surface, you can apply painter’s tape so the drill doesn’t slip and cause damage.
If you want to avoid drilling altogether, self-adhesive handles or clip-on handles are alternatives—although their load capacity and durability may be somewhat limited. If the doors are reasonably stable anyway, I believe conventional screw-on handles after drilling are the better choice.
I’m also curious: Are your doors a solid color or do they have a specific surface finish? This can influence your choice of handles, especially if you want to create contrast or maintain a minimalist look.
Best regards and good luck with your project!
TEOZAR
22 Aug 2023 14:52
kaubi schrieb:
To protect the surface, you can apply painter’s tape to prevent the drill from slipping and causing any damage.
I would like to add: Be sure to use a spirit level or a drilling template to ensure the handles are perfectly horizontal. This will give your furniture a much more professional appearance.
I also recommend testing the drill holes first on a scrap piece or an unseen area, if you have leftover material. This way, you can also determine the optimal screw length to avoid puncturing through the material or damaging the backside.
Regarding the attachment: The handles usually come with suitable screws, which are typically installed from the back of the door. Since the doors are relatively thin, it’s worth using short screws (10-15 mm (0.4-0.6 inches)); otherwise, the screws might go through the door.
If you prefer more delicate handles, you might consider so-called “push-to-open” mechanisms — handles that are hidden and open the door by pressing. However, the installation is more complex.
KIN42
23 Aug 2023 08:18
kaubi schrieb:
I’m curious: Are your doors a single color or do they have a specific surface finish? This can influence your choice of handles, especially if you want to create contrasts or maintain a minimalist look.
That’s an important point. For example, if you have matte white or wood-effect doors, handles made of brushed stainless steel or in black could create strong accents without being too overpowering.
Regarding drilling: PLATSA doors are often 16–18 mm (0.6–0.7 inches) thick, so you should keep that in mind when selecting screw lengths. I recommend firmly securing the doors before drilling to prevent them from shifting under pressure. Pre-drilling a small pilot hole also helps avoid material splitting.
Alternative handles like leather straps have become popular as well—they’re easy to install, give a modern, cozy look, and are visually less intrusive. For installation, simply use small screws or rivets, which hold surprisingly well.
If you want more advice or product recommendations, feel free to ask.
