ᐅ How can I adapt IKEA PLATSA for use in rental apartments?
Created on: 22 Nov 2023 08:17
maceo
maceo
22 Nov 2023 08:17
Hello everyone, I’m looking for good ideas and tips on how to adapt the IKEA Platsa system specifically for rental apartments. My main challenge is that many solutions require permanent attachment to walls or structural alterations, which are often not possible or desired in rental properties. Therefore, I’m interested in flexible, removable, and wall-friendly modifications that still provide stability and storage space. Are there clever tricks to modify the system to fit precisely and work practically without drilling or major changes? For example, alternative fastening methods, interior divisions, or additions that improve its use? I look forward to your experiences and suggestions!
peovin
22 Nov 2023 08:43
Hello, for rental apartments I often use clamp brackets instead of drilling. You can secure and adjust the PLATSA with tension rods or pressure bars without damaging the wall.
KNUTGI
22 Nov 2023 09:16
I simply made my PLATSA more stable in my rental apartment by adding self-adhesive furniture pads to the feet. This prevents scratches and improves stability. If you like, you can also wedge small decorative wooden strips underneath. This gives it a nice look while keeping it secure – no drilling needed! 😎
Kinbu
22 Nov 2023 09:57
Hello maceo, I’m happy to help you with that. PLATSA systems are modular by design and can be flexibly assembled using base heights, connecting elements, and shelving units. To protect rental apartments, I recommend the following approach: - Use connectors and screws only within the modules, not for attaching them to the wall, to avoid making holes in the walls. - For securing to the wall, use clamp or tension fittings that can be pressed between the floor and ceiling. Alternatively, there are special wall weights that can be removed without leaving any marks. - Improve the interior organization with boxes, baskets, or adjustable inserts to efficiently divide storage space. Do you already have the measurements of the niche or rooms where the PLATSA will be placed? That will help me give you more precise advice.
Luciandi
22 Nov 2023 10:23
I understand you very well; the issue of "leaving no marks" in rental apartments is often quite frustrating. What has always helped me is placing the modules on feet with a larger base area and adding weight (e.g., heavy items in the lower section) to ensure stability, so there is no risk of tipping over. This way, I was also able to avoid attaching them to the wall.
Kinbu schrieb:
For wall support, I use clamp or tension devices that can be stretched between the floor and ceiling.
That sounds very practical to me as well. Do you have any tips on where to find such tension systems cheaply or easily?
tra_nina
22 Nov 2023 11:05
For structural adaptation of the PLATSA system in rental apartments, I recommend the following: - Use of telescopic tension rods between floor and ceiling to securely position the furniture without damaging the wall. - Interior divisions with adjustable boxes and drawer inserts for customizable storage without requiring new fasteners. - Use of felt pads or furniture feet to prevent pressure marks and ensure the floor is not damaged. - Avoid drilling by using targeted modular combinations of the individual components. This way, the system remains reversible and the rental agreement can be complied with without issues.
