ᐅ How can damage to the IKEA Brimnes surface be prevented during transport?
Created on: 31 Mar 2022 17:32
MiglaHello everyone,
I hope to find people here in the forum with experience in transporting furniture, especially with the IKEA Brimnes series. My question is quite specific: How can damage to the IKEA Brimnes surface be avoided during transport?
I am particularly interested in tips on how to reliably prevent scratches, dents, or similar surface damage—whether when loading into the car, during the trip, or when unloading and later moving the furniture inside the home.
Although I have not yet assembled the furniture, the panels look delicate at first glance, and I definitely want to avoid leaving any marks during transport that might become visible later.
Are there proven methods, suitable packaging materials, or handling techniques that can make transport gentler?
I look forward to your detailed assessments and advice!
Hello Migla,
First of all, an important point: The surface of the IKEA Brimnes furniture is usually coated and therefore prone to scratches and pressure marks. Here is my structured approach to avoid damage during transport:
- Preparation: The furniture panels should be wrapped with a soft but sturdy protective cover before transport. Special furniture blankets or thick wool blankets are recommended. Plastic wrap alone often slips unnecessarily and can cause friction.
- Securing: After wrapping, I secure the covering with wide packing tape – but never stick the tape directly onto the furniture surface, as the adhesive can leave residue or cause damage. So, wrap the blankets first with strips that you can remove after securing.
- Transport in the vehicle: Place the furniture pieces as flat and stable as possible, ideally supported on a smooth surface without direct pressure from other objects. Make sure not to store sharp or heavy items against the surface.
- When loading and unloading, always use careful, two-handed lifting techniques to avoid scratches from accidentally bumping into sharp edges of the vehicle interior.
Summary:
- Protect furniture with soft, sturdy blankets
- Use tape only to secure the protective material, not on the furniture itself
- Store flat and without pressure during transport
- Handle carefully when carrying
I hope this helps! Good preparation will save you a lot of trouble.
Summary:
Hello Migla,
Before I give practical advice, I would like to know more about your transport situation: Are you driving privately with a car, using a van, or having the furniture delivered by a freight company? This is crucial for the best way to secure the items.
Now about the surface of the Brimnes furniture: The mostly melamine-coated surfaces are prone to scratches and react sensitively to pressure points. Therefore, it is wise to cushion these areas well with soft padding that does not slip underneath.
Here is my detailed procedure:
1. Preparation:
- Unpack all parts to ensure careful handling and prevent damage already during unpacking.
- Stack unassembled panels side by side on a soft surface (e.g., carpet or foam) if possible.
2. Padding:
- Using bubble wrap is good but not sufficient on its own.
- First apply a soft felt or furniture blanket, then bubble wrap on top to avoid scratches and larger pressure marks.
3. Securing in the vehicle:
- Fix the furniture pieces with ratchet straps so they don’t shift.
- Place shock-absorbing mats underneath if available.
4. Lifting technique:
- Always carry so that edges don’t press against hard surfaces.
- If possible, arrange helpers to avoid tipping movements.
5. Additional tips:
- For longer transports, extra foam corner protectors are recommended for especially vulnerable cabinet edges.
Important: Time plays a role – moving slowly and carefully protects the surface more than rushed handling.
I hope these details help you make your transport as efficient and gentle as possible. If you want, please share more information about the delivery and the route.
1. Preparation:
2. Padding:
5. Additional tips:
TEBILO schrieb:
If possible, organize helping hands to prevent tipping movements.This is a very important point. Tipping movements often cause pressure marks or scratches on the edges of the Brimnes furniture. Additionally, I recommend planning the transport so that heavy loads do not directly rest on the surface or cause it to shift.
naujon schrieb:
Flat, pressure-free storage area in the vehicleThe second essential criterion. Ideally, the storage area in the cargo space should be level and covered with a soft underlay. If these conditions cannot be met, at least non-slip mats should be used to prevent sliding.
In summary:
- Carefully protect furniture pieces before transport with furniture blankets or wool covers
- Place wrapped packages precisely and gently in the transport vehicle
- Minimize tipping movements and pressure marks by using helpers or appropriate aids
- Under no circumstances store hard or sharp-edged objects directly next to the surface
This way, visible surface damage during transport of the IKEA Brimnes furniture can be reliably avoided.
