ᐅ How can damage be prevented during the transportation of BILLY shelves?
Created on: 1 Oct 2023 08:07
salih36Hello everyone,
I recently bought a few BILLY shelves from IKEA and plan to transport them soon—both by car and later by freight. Unfortunately, I’m concerned that the shelves might get damaged during transport, such as scratches, dents, or warped wood parts.
So, my question to the community is: How can damage to BILLY shelves be best prevented during transport?
I’m especially interested in practical advice on how to pack the shelves, which protective materials are suitable, how to secure them properly inside the vehicle, and if there are any special precautions when loading and unloading.
It might also be helpful to know whether it’s better to transport the shelves fully assembled or disassembled.
I’m looking forward to your experiences and tips!
Hello salih36,
I think your question is very well formulated, as transporting BILLY shelves can indeed be tricky, especially when they cannot or should not be disassembled.
In general, I recommend the following steps:
1. Disassemble: If possible, completely take the shelves apart by removing the shelves and dismantling the frame. This helps minimize damage and pressure marks.
2. Protection: Wrap all individual parts with bubble wrap or blankets. Pay special attention to the edges, as the surface is often very delicate there.
3. Securing: In the vehicle, lay the parts down and secure them well with straps or tie-downs to prevent shifting during transit. Avoid hard impacts between parts.
4. Loading and unloading: It’s best to work with two people here to avoid bumping edges and surfaces against door frames or floors.
A personal tip: If you don’t have many packing materials at home, you can also ask IKEA for the original boxes—they are designed for transport.
I hope this helps as an initial guide! 🙂
GiRoyce schrieb:
Edges especially need good protection Absolutely right! I would also add: An affordable but effective solution are these foam edge protectors, usually used for packing furniture. I always wrap them around the corners and edges of BILLY shelves, and it really makes a difference.
Bubble wrap can sometimes be awkward to handle, but these foam corners are smooth and fit securely. This way, you avoid any unsightly dents.
Another tip from me: When transporting in a car, always put a sticker saying "Fragile". Otherwise, the shelves sometimes look like luggage flying around everywhere. 😉
Oh, and if you take the shelves completely apart, don’t forget to store the screws in small bags – otherwise, you’ll spend ages searching for them when reassembling!
I would like to go into more detail here because I am very familiar with the transport issues concerning BILLY shelves.
1. Material and Sensitivity:
The surfaces of BILLY shelves usually have a thin melamine coating, which seems durable but can easily scratch or chip under friction or pressure. Therefore, avoiding direct contact between untreated surfaces is extremely important.
2. Disassembling or Transporting Whole?
In theory, the shelves or at least the boards can be removed, but the side panels are often connected and made from large boards. Transporting entire side panels increases the risk of warping, which can be difficult to fix.
3. Packaging:
I recommend wrapping the shelf components in at least two layers of protective material. For example: first a layer of felt-like furniture blankets, then bubble wrap. This creates two insulating layers against impacts and pressure.
4. Loading and Securing:
When stacking in the vehicle, make sure no sharp edges are resting against each other, as this causes pressure marks. Also, the parts must be secured with tie-down straps on a stable, level surface to prevent shifting even during sudden braking.
5. Care When Loading and Unloading:
This is where most damage unfortunately happens. I recommend wearing work gloves for a good grip and to avoid contact with hard surfaces while lifting, and if possible, having a second person help carry at both ends.
I am curious: What kind of vehicle or setup do you plan to use for the transport? That can influence the best approach.
3. Packaging:
GOLO42 schrieb:
I’m curious: In which vehicle or frame are you planning the transport?Thanks for the detailed tips!
Regarding transport: The shelves will first be brought home from IKEA in a station wagon (with the rear seats folded down). Later, however, there are plans to rent a small truck for a move and take the shelves along there.
I plan to partially disassemble the shelves. Of course, I will pack the screws in small bags.
I’m just wondering if securing the parts with blankets and straps will be enough for transport in the car, or if I need any special reinforcements.
Also, I’m uncertain how best to prevent paint layers or edges from getting damaged by bumps. Are there any common protective measures for such short trips?
For short car trips, it is usually enough to wrap the parts with blankets or old towels and secure them firmly with ratchet straps.
You can also attach edge protectors made of foam or cardboard around the delicate corners.
Make sure nothing can shift during transport to keep everything intact.
