Aslampra6821 Dec 2015 08:42Hello everyone,
I have the following problem and hope for your help: I own several BILLY shelves from IKEA, which I mainly use for storing books and files. Unfortunately, I have noticed that mold has developed in some areas in the past—probably due to moisture or insufficient ventilation. My question is therefore very specific: How can BILLY shelves be effectively protected against mold, especially under typical indoor humidity conditions and possibly when placed near exterior walls?
I am trying to understand the cause of the mold as precisely as possible and am looking for practical measures that I can carry out myself. For example, I am interested in advice on the correct positioning of the shelves, ventilation behind them, or also on material protection. It would also be helpful to know whether sealants or special products could be effective. Many thanks in advance for your tips!
Aslampra68 schrieb:
How can BILLY shelves be effectively protected against mold, especially under normal apartment conditions?Do not place the shelves directly against cold exterior walls; use spacers at the back. Ensure regular air circulation, for example with air vents or by keeping a gap between the shelves and the wall. Always keep moisture under control.
pauPierce22 Dec 2015 11:07Jan31 schrieb:
Do not place the shelves directly against cold exterior walls; use spacers at the back.This is a very important first step, which I would like to explain in more technical detail here. BILLY shelves are made of particleboard with a foil coating that is resistant to light moisture but not completely waterproof. If a shelf is placed directly against a cold exterior wall, the interior side of the wall can become damp due to condensation. This is exactly where the risk of mold arises.
I recommend maintaining a gap of at least 2 to 3 cm (about 1 inch) from the wall. This can be achieved using small rubber pads or wooden blocks. This allows air to circulate behind the shelf, enabling moisture to escape more quickly.
Additionally, the indoor climate should be monitored: relative humidity should ideally be kept below 60%. This reduces the chance of condensation forming. If this is ignored, even the most clever setup won’t help.
In cases of acute moisture problems, silica gel packets placed inside the shelves can help by absorbing excess moisture. I also recommend occasionally cleaning the back of the shelves and, if necessary, applying a special anti-mold paint or sealant designed for wood surfaces. However, this should be done before assembly, and the adhesion to the foil coating must be checked.
I would be interested to know exactly how the shelves are currently positioned and how the room’s humidity was measured. Such details are always helpful.
pauPierce schrieb:
In cases of acute moisture problems, so-called silica gel packets can help when placed throughout the shelves.That is a really helpful addition! I would also like to generally point out that mold growth on furniture, especially on particleboard, is very often caused by unfavorable temperature and humidity conditions.
Besides spacing and air circulation, regularly ventilating the home helps—ideally by quick, thorough airing rather than constant ventilation. Many tend to leave windows slightly open continuously during the colder months, but this is actually counterproductive.
For BILLY shelves, you might also consider a special impregnation treatment for the wood surfaces, available from specialist retailers. It prevents moisture from penetrating the material without significantly altering the appearance.
Furthermore, I recommend ensuring sufficient ventilation especially on the lower shelves and avoiding placing items directly against the back panel so that air can circulate.
As pauPierce rightly says, monitoring indoor humidity is also very helpful. Do you have a hygrometer? That’s often a good first step to take targeted measures.
If you like, I can also put together a list of useful products and ventilation techniques.
