I have an IKEA Malm bed frame (140x200 cm (55x79 inches)) and I’m starting to worry about how stable and secure the frame really is. After some time, I feel like the bed wobbles slightly, especially when moving around or sitting on it.
My main question is: How can a Malm bed frame be better secured to prevent wobbling and increase overall stability? I’m particularly interested in whether there are effective additional measures that can be done easily without special tools, or if there are specific reinforcements or hardware recommended.
I’m looking for tips that improve both durability and safety – does anyone have experience with this or has tried it before?
Thanks in advance!
Thanks in advance!
I really like how everyone here is helping out so constructively! 😊
Just a small tip: If you use metal brackets, make sure to choose the right screws and avoid brackets that are too large. Otherwise, the reinforcement will take up too much space, and the slatted frame won’t fit properly anymore.
Some brackets can be fitted with self-adhesive felt strips underneath. This protects both the wood and the floor – a double benefit! 😉
nubar schrieb:
Pre-drilling is essential to prevent the wood from splitting or cracking when driving in screws.I completely agree. Using the correct drill size for pre-drilling can significantly improve stability while minimizing the risk of damaging the wood.
It also helps to insert screws slowly and with controlled pressure, rather than forcing them in. This way, you can sense when it becomes tight.
Thanks for the helpful tips so far!
Wesleymau19 Dec 2022 11:35Great, thanks to everyone who takes the time to respond so thoroughly.
I will now check all the screws and tighten them again. After that, I think I’ll try installing the metal brackets, but I’ll drill pilot holes first. I will also check if adding a central support beam to my Malm is possible, that sounds like a good idea.
I’ll let you know if I have any more questions!
