ᐅ How are the corners of IKEA PLATSA cabinets professionally joined?
Created on: 26 Jul 2021 09:37
Pardan
Pardan
26 Jul 2021 09:37
I am currently facing the challenge of connecting the corners of IKEA Platsa cabinets in the most professional and stable way possible. I am particularly interested in which methods or joints are best suited to create a durable corner connection that looks clean and holds firmly without frequent adjustments.
What techniques does IKEA typically use for this? Are special fasteners recommended, or are there craftsmanship tips that have proven effective? I want to avoid any wobbling or damage over time, so detailed advice would be appreciated—such as how to best combine screws, dowels, connectors, or other components and how to properly assemble the corner joint.
Thanks in advance for your expertise and tips!
barda6
26 Jul 2021 10:12
IKEA PLATSA cabinets are typically assembled using special Lamello connectors and screws. The corners are usually reinforced with metal brackets and angle screws. It is important to secure the back panels well, as this significantly increases stability.
hauklo
26 Jul 2021 11:27
For professional corner connections in IKEA PLATSA cabinets, installers typically use a combination of Lamello connector plates to create a strong, friction-based bond between the panels. The corners are often further reinforced from the inside with metal brackets to ensure corner stability and prevent twisting.
Precise measuring and the use of all supplied fasteners (screws, dowels, Lamello connectors) are crucial. The rear installation of cross battens or back panels in tongue and groove joints provides additional stability by locking the entire construction at right angles.
It is also important to align and clamp the joints properly when screwing. It is recommended to press the cabinet bodies together with clamps before final assembly to enable a tight, play-free gluing or snapping of the connectors.
KUDAISY
26 Jul 2021 17:05
I am pleased to provide a more detailed response here, as the topic of corner joints in PLATSA requires a precise approach.
1. Essentially, IKEA uses so-called Lamello connectors (also known as biscuit joints) in PLATSA, which are inserted into precisely cut grooves. These ensure a form-fitting and accurate connection between panels, prevent lateral shifting, and provide stability.
2. Additionally, metal brackets are often used in the corners and secured with screws. These brackets are essential to make the corner joint durable and load-bearing. They prevent pulling apart or twisting under stress.
3. Another important aspect is the back panel, which in IKEA PLATSA is typically installed using a tongue-and-groove system. This back panel significantly contributes to stiffening the construction and prevents warping of the cabinet carcass.
4. During assembly, it is crucial to align the panels accurately. It is best to use an assembly aid or clamps to hold the panels in place while screwing them together. Inaccuracies can later lead to unstable or crooked joints.
5. For higher load capacity, additional metal brackets or screws can be added from the inside of the corners.
Summary: The professional corner joint in PLATSA is a combination of Lamello connectors, metal brackets, and the rear tongue-and-groove back panel. When assembled properly, this results in a stable and long-lasting construction.
derrick34
27 Jul 2021 08:46
KUDAISY schrieb:
The professional jointing of corners in PLATSA is achieved through a combination of Lamello connectors, metal brackets, and the rear tongue-and-groove back panel.
Exactly. I usually add a bit of wood glue to the Lamello dowels, which significantly improves the stability. However, this is not mandatory.
Pardan
27 Jul 2021 12:33
hauklo schrieb:
The rear installation of battens or back panels with tongue and groove joints provides additional stability
Thank you, that makes a lot of sense to me. Do you use the original back panels, or do you sometimes opt for alternative reinforcements/materials?
Also, I’m interested: Are there any practical tips for accurately aligning the Lamello connectors? I’m a bit concerned that if the groove milling isn’t perfectly precise, the joint might end up misaligned or unstable.
Thanks for your feedback!
