I’m trying to get an early start and am already thinking about the wiring for the house that doesn’t exist yet (bungalow is fine).
What I know so far:
A small server/media center will be installed later in the utility room. The network wiring should be done with CAT7.
Five network outlets are needed in the living room.
One outlet in each children’s bedroom/bedroom.
I would also like to equip the kitchen with two outlets. The bathroom will remain without any.
That’s about all for now.
I don’t have exact ideas yet on how I want to implement all of this.
Internet access is obvious. Running cables from the patch panel in the utility room to the rooms. Ideally, using dual-port network sockets (I don’t know the exact technical term, but I think you know what I mean).
That shouldn’t be a problem with CAT7, right?
I’m totally uncertain when it comes to the TV setup. Currently, we have IPTV (one channel for watching and one for recording) and are quite satisfied.
Unfortunately, according to the provider, we’ll only get a 16 Mbps connection later. IPTV will work with that, but when the kids get older and more people are using the network, I’ll really struggle.
So I’m trying to think ahead and am slowly considering a satellite dish. That would mean I’d need to run coaxial cables everywhere, right? Plus, a receiver for each.
How does that work? Can I place one receiver in the utility room and then run star-shaped cables from there to the rooms (kids will also want TV)? Or does each room need its own receiver, with a star setup running from the satellite dish?
What I know so far:
Sebastian7925 Aug 2016 09:07This has nothing to do with the network. Two different programs running at the same time.
Ah, so would it be an idea to run 2 cables into the living room and maybe (I need to think about it carefully) into the children's rooms as well? Or can the receivers generally handle processing 2 channels through one cable? I would like to record one channel and watch another at the same time.
Sebastian7925 Aug 2016 09:24You will always need to use two coaxial cables – otherwise, it would only work with transmitters on one transponder.
I would always provide the children’s rooms as well – they grow older and will eventually have TV needs. Or the rooms may be used differently later on...
You need one cable per device. So, if you want to watch TV and record different channels at the same time, you will need 2 cables at that point coming from the multiswitch.
In the children's rooms, one cable is enough because I hardly think more than just watching TV will happen there. The rest will come from the internet or from the hard drive...
Sebastian7925 Aug 2016 09:28We didn’t do that – who seriously still takes measurements nowadays?
