ᐅ House Planning on an Existing Plot of Land
Created on: 4 Jul 2017 13:47
tepee
we already own a plot of land and are considering the best way to position the house on it.
The plot is 665 sqm (7159 sq ft), approximately 21.5 m (70.5 ft) wide and 31 m (102 ft) long, with access from the south side. The slope is about 1.5 m (5 ft) from south to north and about 2 m (6.5 ft) from east to west. There is a relatively free building area, except for a 3 m (10 ft) setback at the front and rear, as well as the usual boundary setbacks. See item no. 6 in the attached plan.
We would like a house with about 140-150 sqm (1507-1615 sq ft) of living space distributed over the ground floor and first floor (either without or possibly with a high knee wall), plus a double garage. Two fundamental questions are troubling us:
1. With or without a basement? Is a basement advisable on this slight slope? Basically, we could do without a basement, then with a small utility room on the ground floor and a small laundry room on the upper floor, plus possibly a slightly larger garage. However, if a basement would not cost much more due to the site conditions, we would not mind. A partial basement would also be sufficient, but we often read that the cost savings compared to a full basement are minimal. With a basement, the house could also have only 140 sqm (1507 sq ft) instead of 150 sqm (1615 sq ft). We would not want less than that because we would like to have an office/guest room on the ground floor.
2. An equally important question is where and how to best position the house. Due to the southern access, it is unfortunately not so easy. So far, we have the following ideas (the first two are shown in the attached sketch):
a) House with east entrance as far back as possible in the northeast, garage with 5-6 m (16.5-20 ft) driveway in front in the southeast. Pros: a large southwest garden, privacy thanks to the garage. Cons: longer and potentially wet path to the house.
b) House with east entrance roughly centered at the back and garage attached at the boundary to the east side. Pros: direct access to the house, large south garden. Cons: long driveway (snow removal), less western garden.
c) House with west entrance roughly centered at the back and garage attached at the boundary to the west side. Pros: direct access to the house, large south garden. Cons: long driveway (snow removal), no western garden but rather an eastern garden.
We might not push the house fully to the back as far as possible but leave some northern garden instead. So instead of the 3 m (10 ft) minimum distance, perhaps 5 to 7 m (16.5-23 ft). To have a secluded and shaded garden area in midsummer. Does that make sense or not?
I look forward to your opinions and advice. Thanks in advance.
Regards,
Thomas
Lageplan eines Baugebietes mit nummerierten Grundstücken, Straßen und Grünflächen
Lageplan eines Wohngebietes mit markierten Baugrundstücken, Straßen und Nummern.
Übersichtlicher Lageplan eines Wohngebiets mit Grundstücken, Straßen und Häusern
kbt09
21 Feb 2020 15:49
@tepee ... then just make this sketch with a few measurements added and post it here. Unbelievable.
kaho67421 Feb 2020 16:34
tepee schrieb:
The right side of the plan is south = street.
kbt09
21 Feb 2020 17:19
*offtopic* ... @kaho674 ... Katja ... I’m cracking up, I’m just reading your new signature
kaho67421 Feb 2020 17:41
Yes, it became too annoying to always answer the same questions.
Zauberwesen21 Feb 2020 22:43
kbt09 schrieb:
*offtopic* ... @kaho674 ... Katja ... I’m cracking up, I just read your new signature
Please explain – as a mobile user, I can’t see any signatures :-(
kbt09
21 Feb 2020 23:17
@Zauberwesen ... then you just need to log in from your laptop or something, or use the forum function and click on @kaho674. There you will find the tab "Information," where you can also read the signature.
