Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Maria16
21 May 2019 18:16
I agree with KTB and would add that the other part of the upper tile will probably be placed on the back wall, as the line is already drawn there. From the start, the white wall tiles should have been done differently if the height was not wanted visually. But: it’s all a matter of taste.
Z
Zaba12
21 May 2019 18:22
Maria16 schrieb:
I agree with KTB and would add that the other part of the upper tile will probably be placed on the back wall since the guideline is already marked there. From the start, the white wall tiles should have been done differently if you don’t want the height visually emphasized. But: it’s all a matter of taste.
Yes, exactly, tiles will be installed there to reach a height of 120cm (47 inches) above the finished floor level. The shelf and tile piece will be white, so only the actual pre-wall surface will have the wood look.
guckuck2
21 May 2019 18:33
Zaba12 schrieb:
@wilder Verband: From a craftsmanship perspective, wood-look tiles in those sizes are only installed using the random stagger pattern. At least, that’s what Aunt Google told me.
There are no limits when it comes to personal taste.
Well, there are plenty of installation patterns around the world. You just have to know what you like and what makes sense. A straight joint pattern always works and is often seen even in wood-look tile catalogs. But it wouldn’t be my choice; the “fake wood” effect comes across better with parquet-style patterns.
What I actually wanted to point out is that this is not a random stagger, but “something else.” Even a random stagger follows certain rules.
Yosan
21 May 2019 20:35
I really like the front! The laying pattern doesn’t bother me visually at all because of the wood appearance... even though I usually prefer everything to be symmetrical.
Yosan
21 May 2019 22:11
Today, our foundation slab was poured.
Construction site with fresh foundation slab, wooden formwork, gravel, and adjacent residential houses under a cloudy sky
hampshire
21 May 2019 22:25
A foundation slab is a bit unusual. It’s hard to imagine the entire house fitting on that area sometimes, while at other times it seems huge. It’s like depending on the mood.
It’s good to see progress being made.
