Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
blaupuma25 Oct 2018 21:22
One more question.
My electrician says that if you don't want to have your thermostat integrated into the combined unit with the light switch, the thermostat must be installed slightly offset above the light switch. I want a cost-effective solution for the granny flat, but now it looks a bit messy with the wall already channeled.
Has anyone else heard the same?
blaupuma25 Oct 2018 21:24
No, nobody made a mistake.
We overlooked it in the drawing.
So it’s entirely our fault.
Goldi09111 schrieb:
Is the window asymmetrical according to the drawing, or did the masons mess up?
Goldi09111
25 Oct 2018 21:54
Ah, okay. Well, I think there’s definitely room for a case of Radler or shandy there.
Alex85
26 Oct 2018 06:08
That won’t be enough. It’s not a huge effort, but definitely more than just a beer crate. With this offset, you’ll need to build up the wall if you want to keep the same window size.
Wickie
26 Oct 2018 06:53
blaupuma schrieb:
My electrician says that if you don’t want to have the thermostat integrated into the same unit as the light switch, the thermostat must be installed slightly offset above the light switch. I want a cost-effective solution for the granny flat.
Why would it be cheaper if the light switch and thermostat are not combined in one unit?
Müllerin
26 Oct 2018 08:05
Our thermostats are also installed higher up, but not staggered.
