Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
HöKi2018
13 Jun 2018 21:53
As of today, we have water supply in the house, and the heating system has also been installed. Tomorrow, electricity, telephone, and empty conduit for fiber optic wiring are scheduled to be installed.
White heating system/boiler in the basement with display, pipes, and insulation at the upper section.
Water filtration system made of brass pipes with pressure regulator, filter cartridge, and blue shut-off valves.
Arifas14 Jun 2018 22:25
Our screed can be done today – with a delay of 2 days. Next week will be the utility connections.
Dark interior corridor with column and teal-colored skirting boards in the hallway.
haydee
14 Jun 2018 23:10
@Höki which system do you have from Stiebel Eltron
HöKi2018
15 Jun 2018 09:47
haydee schrieb:
@HöKi2018 which system do you have from Stiebel Eltron
We have the LWZ304 Trend unit
R.Hotzenplotz
15 Jun 2018 22:25
What cable bundles! My goodness!
Construction site with many colorful cable bundles hanging in front of a red brick wall next to a window.
Quite close to the wall:
Construction site interior with raw brick walls, pipes, and cables on the floor
Now only the power supply is missing:
Wall-mounted sanitary fitting: Blue round part, brass valve, black hose, STOP sticker.
This seems to be the gas line:
Raw construction ceiling area with visible pipes and cables
The electrical wiring isn’t installed vertically or horizontally, but the electrician says that’s not a problem.
Installed green and black cables on a white plastered wall, red end caps visible.
Uncovered wall with visible electrical wiring in the shell construction
X
xray107
15 Jun 2018 23:31
@R.Hotzenplotz
In the first picture, is the yellow cable a LAN cable?
Isn't it supposed to be inside a conduit?
