The floor has now been installed at an acquaintance's place. The expansion joints were not maintained; instead, they were chipped out and filled with synthetic resin.
Where the flooring changes to tile, a wide tapering layer of leveling compound was applied to avoid any edges.
The flooring changes beneath the door panel. A very fine silicone joint will be applied here.
Joe, if you apply the filler over a wide area, you end up with a floor that isn’t level over a large surface.
I think that’s much worse than having a small edge that only someone who is completely drunk would trip over—that would be a self-inflicted problem.
Yes, you could raise the entire screed in the vinyl rooms. But we didn’t consider that. So what? It is what it is. Otherwise, I think my brother and I did a pretty good job installing the planks. Everything is straight, level, and solid. Karsten
blackm88 schrieb:
We will install a different curve, so it won’t be as deep. With heavy rain, there might be a bit of gurgling at the last bend before the downpipe due to uneven flow velocity, but otherwise, it should be fine, I’d say.
Nordlys schrieb:
Otherwise, I think my brother and I managed the boards quite well. The most important thing for the boards is always to have at least a hand's width of ground beneath the house.
winnetou789 Oct 2017 03:22Joedreck schrieb:
At a friend’s place, the floor has just been installed. The expansion joints were not preserved but instead removed and filled with synthetic resin.
When changing the floor covering to tile, the surface was leveled extensively to avoid any edges.
The covering changes beneath the door leaf. Here, a very fine silicone joint is applied.
I had read that resin filling should only be done with trowel cuts and that proper expansion joints need to be maintained in the flooring.
I’m also not sure if Joe explained that correctly. Filling the joints with epoxy makes no sense because then there would be no expansion or contraction at all—instead, the screed is more likely to crack if epoxy is used and it can’t flex. However, they might have used a tough elastic single-component polyurethane resin, which would make sense. We simply left the blue foam strip in place, trimmed it short, and sealed over it with silicone. We used glazing silicone because it adheres very well and is highly flexible. Karsten
Unfortunately, I am only the second point of contact. I just receive reports and can pass them on as they are.
I will also report on how it feels to walk on a slight incline and whether it is very noticeable.
I am also only familiar with expansion joints being carried over.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 187
- 188
- 189
- 190
- 191
- 192
- 193
- 194
- 195
- 196
- 197
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
