ᐅ Electrical / Power / Telephone Service Connections
Created on: 5 Nov 2017 14:39
Kusserob
The last utility provider (electricity) has now completed the house connection for me. They extended the underground cable and pulled it into the house.
When I asked if the underground cable should be further protected with a conduit, they said it wasn’t necessary. I was advised to backfill the cables with sand and then refill the trench normally with gravel.
Only the water company wrapped their PE pipe with a cheap corrugated pipe.
Is this no longer necessary nowadays? The cables and pipes that come directly from the ground into the trench aren’t even surrounded by sand.
I’m a bit worried about closing the trench like this, in case a pipe gets damaged later and everything has to be dug up again.
Nordlys
8 Mar 2018 22:31
Four connections: electricity, water, gas, telephone, each through separate conduit pipes or individual entries. All positioned side by side in the utility room. Already prepared in the concrete slab.
Kaspatoo8 Mar 2018 22:31
multi-utility installation included, costs covered in the total price
what is expensive anyway?
and if there were cheap options, would you care if they protect against water? I wouldn’t
have you tried googling?
you can find many offers around €800
housedreamer31 Mar 2018 22:33
In case anyone is interested:
We now have a perimeter seal for just under 50 euros, which meets the requirements of our utility company :-)
andreashm
11 Apr 2018 14:10
Kaspatoo schrieb:
I also had an empty conduit installed in case an additional cable connection is needed later
It is indeed advisable to include an extra empty conduit at this stage if you plan to participate in the FTTH/FTTB program or do not want to rule it out entirely. Fiber optic expansion for high-speed internet will come sooner or later.
dome2711 Apr 2018 14:20
The municipal utility company offers the multi-utility conduit installation free of charge for us if a gas connection is laid to the property.
However, I am not sure if this offer is standard practice.
