Our heating engineer said he would usually install a circulation pump, but it could also be omitted. Operating costs would be about 30–50 € per year, and he estimated that it would need to be replaced every 6 years.
Of course, we don’t want to wait 30 seconds for the first warm water. He also mentioned that he can reduce the pipe diameter to somewhat lower the wait time.
Does anyone have experience with these pumps – from what pipe length or distance would you recommend installing one?
Another topic was the ventilation of the utility room, bathroom, and kitchen – he said it might be possible to install an air admittance valve (also known as a "mushroom valve" or similar) to avoid venting through the roof. Does anyone know about this? Does it cause any odors? I find that hard to imagine.
Thanks and best regards.
daniels874 Oct 2015 11:06Especially for seldom-used faucets, installing a hot water line is not worthwhile. For example, in a guest bathroom. A small amount of hot water can be heated using a tankless water heater. With a looped hot water pipe, you have double the surface area, which increases heat loss. Also, if hot water is constantly circulating in the line, the temperature difference is relatively high, leading to greater heat loss. From an economic standpoint, a tankless water heater is at least not worse, unless you truly need hot water at every sink.
