ᐅ Hot Water Recirculation Pipe – What Insulation Should Be Used?
Created on: 29 Aug 2016 15:34
Schmello
I am planning to replace my hot water line with a loop system including a circulation pump.
All routes are open.
It will be aluminum composite pipe 20x2 mm (0.8x0.08 inches).
Now, there are numerous types of insulation with different thicknesses...
I would prefer not to use the wrong one.
Can you recommend something? Preferably pipe with insulation already attached...
Thanks in advance.
Thanks in advance.
Peanuts745 Sep 2016 07:39BeHaElJa schrieb:
Just because people do things doesn’t mean they should be allowed toWell, the water utility also has to give their approval...
As long as everything goes well, no one pays attention to it. It becomes a real problem when something goes wrong. This happened a few years ago in this city. A diligent DIYer managed to contaminate the fresh water supply of an entire district. The utility company took several days to identify the source of the bacteria, and during that time the district was without fresh water. I don’t want to imagine the costs involved (or whether the insurance covered it).
In some municipalities or public utilities, a copy of the installer’s certificate issued by the regional installer committee must be submitted along with the applications for water connection, drinking water system, and rainwater harvesting system. Otherwise, no water meter will be installed. This ensures that at least the technical connection requirements for the drinking water and rainwater harvesting systems are properly met.
Peanuts74 schrieb:
Well, the water utility also has to give their approval...I have already written a bit about what is possible and permitted.
If your acquaintance is not registered as a master plumber in the water supplier’s installer directory, or has not obtained a guest permit upon request, he definitely would not have received a water meter.
In the situation you described, there is probably a licensed installer colleague involved who is trying to legitimize installations made by others with his signature.
It would be great if we could get back to the original question here.
Olli
Sebastian795 Sep 2016 18:01Here, nobody wanted to know who was installing it – there was nowhere to specify this when applying for the connection.
We actually had the connection before the wiring inside the house…
