ᐅ Building a Single-Family Home – Solid Construction or Prefabricated House?
Created on: 30 Apr 2017 21:27
Elly S.
Hello everyone!
My partner and I are currently gathering some information and ideas for our own home. As is often the case, we have already spoken to a few homeowners and asked for their opinions regarding price, size, etc., and every view is different, so we hope for some helpful advice here in the forum as well.
Our first question is: prefabricated house or solid/conventional brick-and-mortar house?
And if solid house: is it possible to build a house about 110 m² (1,184 sq ft) in size, without a basement, without any extras like bay windows, dormers, etc. (just a simple rectangular shape), without cutting bricks, and with some help from friends or relatives for around €200,000?
What is cheaper, a single-story or a multi-story house with a smaller foundation slab?
And if it is a prefabricated house, then: how long can it actually last if we find a good construction company and maintain it well? Is it repairable once the expected lifespan and manufacturer’s warranty have expired (we mean major issues such as a crack in the wall)? Is it still true these days that a prefabricated house loses value and can no longer be sold at a reasonable price later, compared to a solid house?
Elly
11ant2 May 2017 14:40
Curly schrieb:
Weren't they made of oak?
Yes, exposed timber framing requires different types of wood compared to when it is covered with cladding or plastered over.
Curly schrieb:
Regardless of whether prefab houses are ultimately as good as solid-built houses, a large portion of potential buyers simply prefer solid-built homes, as they are easier to sell.
That’s why I said the relevant factor is ultimately the prejudices of the financing bank. On the market, location and amenities count most, as well as whether the house requires major renovations. Especially in the high-end segment, comparisons are made on an equal footing. For typical entry-level homes, the “simple house” image still plays a stronger role.
derdom schrieb:
Well, for example, I wouldn’t buy a prefab house from the 1980s.
Depending on the exact year in the 1980s, formaldehyde could still be an issue. Asbestos and lindane had already been phased out by then but affected solid-built houses just the same.
derdom schrieb:
The question is, what will newly built houses look like in 10, 20, or 30 years? Will they be perceived the same, or will opinions have changed?
In ten years, I expect a depreciation mainly for houses with external thermal insulation composite systems (ETICS) and without basements, rather than the value classification sticking rigidly to timber or masonry. The new point of contention could more likely be mechanical ventilation with heat recovery than prefab versus traditional construction – especially since more solid-built homes also have stud walls (as drywall interior partitions on upper floors). The prevalence of underfloor heating is increasing to an extent that it could make radiator heating seem outdated.
The “timber or masonry” debate with its potential to polarize will likely become nostalgia for the next generation.
Elly S.
3 May 2017 09:04
Nordlys schrieb:
A few tips to save costs. Always design with a rectangular floor plan without bay windows, dormers, etc. Place all water supply and drainage on one side, preferably at the front. Use the same 110cm (43 inches) structural opening size for all windows. Avoid as many floor-to-ceiling terrace doors as possible—one is enough. Use a 110cm (43 inches) front door, without large side panels. Choose white-primed spruce for the roof soffits. Paint it yourself with Consolan or a similar product.
Make sure the kitchen wall dimensions fit a prefabricated corner kitchen from available offers.
All of this can save you roughly 10,000 to 15,000.
If you can find a contractor who supplies Polish or Czech windows, that’s another 2,000 saved. Smooth white interior doors save another 1,000.
None of these plans reduce the value or durability of the building. Karsten
That’s a concrete and helpful statement!
haydee
3 May 2017 10:44
Curly schrieb:
Weren’t they made of oak? Regardless of whether prefabricated houses are ultimately as good as solid houses, the majority of potential buyers still prefer solid houses, as they are easier to sell.
Sabine
No. Ideally, the ceilings and crossbeams were made of spruce, and the vertical beams for walls were made of beech or oak.
We actually found almost every type of wood that grows in our area during the demolition.
According to my grandfather (an old-school carpenter), it is important that the wood is cut according to the proper lunar phase.
Caspar2020
3 May 2017 10:58
haydee schrieb:
According to my grandfather (a traditional carpenter), it is important that the wood is cut according to the correct lunar phase.
This is actually called "lunar timber" and can still be purchased today.
Usually, winter felled wood was considered sufficient or was actually the only type used for construction.
