ᐅ The hinges on my KALLAX never last long – what alternatives are there?
Created on: 21 May 2024 08:17
samed43
I have been having an issue for some time now where the hinges on my IKEA KALLAX shelving unit never last very long. Whether I replace them with new ones or try to adjust them, after a few months or sometimes just weeks, everything loosens up, the doors hang crooked, or almost fall out. I suspect that the material or design of the hinges is not ideal for the thin panels of the KALLAX.
My question for you: What alternatives are there to the original KALLAX hinges that hold up better and are more durable? Do you have experience with specific hinges, different mounting methods, or perhaps even completely different solutions to securely and reliably attach doors to KALLAX units long-term?
I appreciate any tips – including where to buy or specific models! Thanks in advance!
Filippo schrieb:
What is your usage pattern? Are the doors opened and closed frequently?Good question. The shelf is in my living room, and the doors are opened about 3-4 times a day on average, usually quite gently. These are not heavily used doors like those in the kitchen or children’s room. However, I would of course expect the hinges to last at least 2-3 years without needing adjustment.
Nabla64 schrieb:
Pre-drilling with a drill bit narrower than the screw diameterCould you explain that in more detail? What drill bit diameter is ideal? I’m often afraid of splitting the wood or making the hole too large.
Thanks for the tips so far. I’m already looking into cup hinges, but the suggestion about reinforcing the door sounds interesting and practical.
Hello samed43,
regarding pre-drilling: The goal is for the screw not to cut into the raw MDF, but to turn smoothly into the material without applying too much pressure, which helps prevent cracking or splintering.
I recommend the following approach:
- Determine the core diameter of the screw (the shaft without threads). Use this diameter as the drill bit size.
- For example, furniture screws with a 4 mm (0.16 inch) outer diameter may have a core diameter of about 2.5–3 mm (0.1–0.12 inch). Therefore, use a 3 mm (0.12 inch) drill bit.
- Drill slowly and precisely, preferably slightly shorter than the screw length.
- Avoid drilling too deep so the screw threads have enough material to grip.
If you keep this in mind, the MDF will hold the screw better and the material won’t crack. It’s also important to use quality screws that minimize splintering.
For insert nuts, you need to drill a hole that fits the nut exactly, then carefully tap it in with a hammer (be careful!). However, this option is a bit more complex.
Good luck with your attempt! 🙂
I completely understand how frustrating it is when hinges keep breaking. I had the exact same problem with an IKEA dresser. It can be really annoying to constantly deal with faulty hinges.
What helped me was replacing them with sturdy metal strap hinges, the kind usually used for doors. While these hinges are visible from the outside, which not everyone likes, they are often much stronger and last significantly longer than the small cup hinges.
The most important thing, however, is to reinforce the wood where the hinges are attached. I added a thin wooden strip to the back, which is not visible, and screwed the hinges into that. This better distributes the load and greatly improves durability.
In addition, I regularly tighten the screws slightly – a small maintenance step that extends the lifespan of the doors and hinges.
I hope this helps! And don’t worry, almost everyone who works with budget furniture experiences something like this. 🙂
All the best!
All the best!
samed43 schrieb:
Are there perhaps hidden reinforcements that are discreet?Hello samed43, yes, hidden reinforcements are possible and often the best solution. If you don’t want to affect the appearance of the doors, I recommend using thin metal reinforcements, so-called "furniture plates," which can be installed on the inside of the door or at the sides.
These metal plates are narrow and provide good stability. They are fixed with small screws. There are also adhesive tapes reinforced with carbon fiber available nowadays, but those are more experimental.
Another option is small wooden strips that can be glued over an area inside the door to strengthen it. This is barely visible and significantly increases rigidity.
Have you considered testing hinges from Blum or Hettich? These brand-name hinges often come in special versions for thinner doors. Sometimes the additional cost is worth it for lasting quality.
