ᐅ Heated and spacious sports room next to the garage? – Looking for ideas
Created on: 21 Nov 2019 15:45
ludwig88sta
we have found a plot of land near Regensburg. It is just over 1,000 sqm (10,764 sq ft) and is almost square in shape. Therefore, we are not restricted in the building’s floor plan. We want to build using solid construction (either expanded clay or insulated bricks) with walls of 36 cm (14 inches) or preferably 50 cm (20 inches) thickness.
Originally, I wanted to place two prefabricated garages away from the house, closer to the street. However, since we also want a room of about 3 x 6 m (10 x 20 ft) for sports (with barbells, pull-up rig, air bike, etc.) next to the garage, we have moved away from the more economical prefabricated garages. Instead, we are now considering situating the garages east of the house, connected by a door.
There are some special requirements for the sports room:
- it must be at least 3.00 m (10 ft) high (ideally 3.20 m (10.5 ft))
- about 3 x 6 m (10 x 20 ft) floor area
- not very cold in winter, unlike a typical garage in winter
Does it make sense to build the sports room directly east of the house, with the double garage further east of that? Is a double garage height of 3.00 m (10 ft) too high? Even with a pitched roof, as we envision for the house. Also, if the garage is directly adjacent to the house, is it usually heated, insulated, or neither? Because the sports room really shouldn’t be around 5°C (41°F) in winter.
We don’t have a floor plan for the house yet. For now, we’re focused—although it might sound odd—on planning the sports room first. Oh, and because of the 3 m (10 ft) height and since we like to spend time outside in the sun in good weather in front of the garage/sports room, a basement location for the sports room is out of the question.
Basically, the room should look somewhat like this. However, not like a typical garage, but as a single room (although with a roller door or a wide door and windows for good ventilation). A single room would also be better for heating purposes, right?
Maybe you could give us some ideas on how and where to best accommodate a high-ceilinged, heated sports room in a new build. Next to the garage? Or would two prefabricated garages plus the sports room attached to the east side of the house be better?
Thank you very much for your time and any possible tips.
Marius
Marius
ludwig88sta22 Nov 2019 16:01rick2018 schrieb:
Especially since it is not permitted according to the garage regulations In which section of the garage regulations is that stated?
Thank you.
rick2018 schrieb:
According to the garage regulations, it is not permittedA "garage" cannot legally be used as a sports room – however, this does not prevent a space that is legally classified as a habitable room or small hall for such uses from having the shape or appearance of a garage. Therefore, using a small prefabricated house that is otherwise sold as a "garage" for a sports room is, in my view, not prohibited.https://www.instagram.com/11antgmxde/
Thanks.In none. According to the garage regulations in Lower Saxony, it only states that a garage is fundamentally (!) intended for the storage of one motor vehicle and regulates the storage of gasoline and diesel fuel.
Now I understand what was meant by a border garage. No, since we have a relatively large lot, we don't plan to build directly on the boundary. And as I said, maybe 2.8 m (9 feet) height will be sufficient.
PS: Of course, we don’t have the climate of California or Florida here, but when the weather permits, there is nothing better than being able to do your exercises in an open garage or even just outside the garage.
Thanks again to everyone so far.Roman Fritz trains in his basement. That means you don’t need that kind of ceiling height for fitness and bodybuilding. If this is really important to you, you should know who he is.Zaba12 schrieb:
Roman Fritz trains in his basement.Scout schrieb:
Rich Froning or Mat Fraser are more like the references.I don’t know any of them and just heard a great word for that from Cordula Stratmann: “sportophob” *LOL*https://www.instagram.com/11antgmxde/
