ᐅ Help: Malm Nightstand Scratched Due to Moisture – What Can I Do?
Created on: 4 Nov 2015 08:34
michelan31
I hope you can help me: I own a Malm bedside table from Ikea that has developed some scratches and dull spots on the surface due to moisture. The moisture likely came from wet glasses left on it for too long or possibly condensation from a drinking glass. Now, I’m wondering which methods are effective yet gentle enough to repair or reduce these visible damages.
Is it possible to treat this with household remedies like vinegar or oil, or would professional furniture care, sanding, and repainting be more appropriate? I don’t want to risk causing further damage to the wood. Does anyone have experience with this exact model or the coated wood the bedside table is made of?
Thanks in advance for your advice!
JAMESONB415 Nov 2015 11:18I would definitely avoid sanding on foil surfaces.
Try using special furniture care pens for foil, which visually fill in small scratches.
Alternatively, you can also use a cloth soaked in wax, which often works wonders.
Let's be honest, most maintenance methods for film coverings are more cosmetic than truly effective!
That fear isn’t unfounded—it can really happen. So why focus on such a cheap bedside table instead of going for something solid from the start? Film will never provide a perfect surface, that’s just a fact.
Anyone who thinks they can restore the film to like-new condition with a few home remedies is living in a fantasy. It’s better to use a nice tablecloth or coasters—that will actually help more.
This isn’t a problem, but rather a design concept with its limitations. 😉
But sure, try the care sticks, they won’t cause any harm.
michelan31 schrieb:
I’m afraid the film might get damaged while sanding.
SIAURORA schrieb:
Why do people focus so much on such a cheap bedside table?I think that’s a bit unfair. Many probably choose such furniture precisely because of the good value for money.
Your point about the ‘design concept having weaknesses’ is certainly correct from a technical perspective – but sometimes you can learn a lot from these small defects.
michelan31, don’t stress too much. With the advice here, you’re already well equipped. I think your question was very well posed; that keeps forums lively and helps everyone.
A small tip from me: Always use fast-drying coasters and wipe away any moisture immediately—that’s the best way to protect laminated surfaces.
