ᐅ Help Navigating the Roller Shutter Control Jungle
Created on: 6 Jul 2016 11:12
tyr0n
Hello community,
I urgently need help. I am losing track of the different options for roller shutter control.
We have:
Ground floor (GF) 10 roller shutters
GF 1 distribution box
Upper floor (UF) 6 roller shutters
UF 1 sub-distribution box.
We want to:
- Control each roller shutter up/down individually with a push button
- Control all roller shutters on the GF up/down via a central switch
- Central time scheduling for groups or each individual roller shutter
- Possibly later control roller shutters via a sun sensor (but not a must!!)
The plan was:
To implement all this using LOGO. The problem is that on the GF I need 20 outputs for the roller shutters plus additional ones for the central switch.
So, for the GF distribution box I would need 1 x base unit (4 outputs) plus 2 x extension modules (16 outputs) plus another extension module for the central switch???
On the UF, I would need 1 x base unit and 1 x extension module again.
What has been done so far:
The window manufacturer installed 16 elero motors.
Each roller shutter is wired with 5x1.5 mm² cables to the respective distribution box.
Done.
The main question:
Am I missing a supplier on the market who specializes in roller shutter control? All I find are base stations with 4 outputs plus countless output extensions at high cost.
We do not want to rely on wireless control. I have looked into Busch, Gira, Comexio. It comes to over €1,600.
Thank you in advance.
Regards, tyr0n
derelvis
8 Jul 2016 10:56
We have not yet put the control system into operation.
Approximately €900 (around $970) for 8 channels and €500 (around $540) for each additional 8 channels, up to 24 channels.
Everything you want is possible, and of course even more, for example with a LAN module for app control.
Reviews in various forums are quite positive, and the seller seems very knowledgeable and extremely helpful.
8 Jul 2016 12:31
@derelvis
Please follow the forum rules and do not post any advertising links.
derelvis
8 Jul 2016 12:47
We have the Heytech control system.
However, it is not yet operational because the roller shutters have not been installed.
Approximately €900 (about $970) for 8 channels and €500 (about $540) for each additional 8 channels, up to 24 channels.
Everything you want is possible, and of course a bit more. (For example, with a LAN module, app control is also available.)
Reviews in various forums are quite good, and the seller appears very knowledgeable and extremely helpful.
Bauexperte
8 Jul 2016 12:52
@derelvis
Since you neither reply to private messages nor update your profile entry, this is a reminder again regarding the mandatory fields:
https://www.hausbau-forum.de/threads/pflichtfelder.15592/
Regards, Bauexperte
