ᐅ HELP!!! Ikea Base Cabinet FA120
Created on: 21 Dec 2008 10:55
Narcisita
Narcisita
21 Dec 2008 10:55
Hello, I bought my entire kitchen from IKEA and now I am having problems with the base cabinet FA120 (base cabinet with drawer pull-out).
I assembled the cabinet body and attached four drawer slides. Now, a large front panel is supposed to be mounted on the lowest drawers. However, the front panel has no drill holes for this. It seems like the front panel might be incorrect because it only has two large holes for door hinges.
I’m at a loss and don’t know if the front panel is wrong or not. I also think that not everyone has a router at home or can work like a professional carpenter. Has anyone built this kind of cabinet before and can share some advice?
Thank you in advance.
Skyscraper
22 Dec 2008 10:04
Welcome to the Ikea forum!!
Hmm, I don’t have that wardrobe, but are you sure you didn’t attach the front panel on the wrong side??
Otherwise, it might really be necessary to drill the screws in with a cordless drill. That way, it will hold much better than if there were already pre-drilled holes.
Regards, Sky
Klappstuhl
29 Dec 2008 10:08
Hi,
we can help you better if you could upload one or two photos.
Knut
29 Dec 2008 10:18
Hello Narcisita,
Try the hotline. Although I’ve never called there myself, I wouldn’t be surprised if IKEA also has a polite computer voice asking you to press 1, 2, or 3 – that can be quite annoying.
Good luck
Knut
Elch
6 Feb 2014 15:17
Hello Narcisita,
I have two base cabinets from Faktum with the large front. For the doors, at least in my case, there was a paper template included. It was placed on the lower opposite side, and the holes to be drilled were marked using a pin. Since I don’t know if you have the same door, I can only tell you about my experience. I also had two large and four small plugs to cover the holes. One of the mounting holes went through the large plug. The doors are probably used for different models.
I hope this helps you.
Good luck
Elch
Nordkäppchen
7 Feb 2014 10:16
Even though this thread is older, a look at the installation manual reveals quite a few secrets.
Nordkäppchen
