Good morning!
For the edging of the paving or splash protection: How high should the curbs be? They come in sizes from 10 to 30 cm (4 to 12 inches). Is 15 cm (6 inches) enough?
If I set 1/3 of it in concrete, that leaves 10 cm (4 inches) for backfilling with gravel, or if the paving is 8 cm (3 inches) thick, then only 2 cm (1 inch) for the gravel. Would 20 cm (8 inches) be better? Or even 30 cm (12 inches)?
The price difference is negligible, but I imagine handling stones over 40 kg (88 lbs) would be difficult.
What are you using?
What are you using?
hemali200326 May 2019 07:28The higher the better for stability. We chose 30 cm (12 inches) or 25 cm (10 inches); I don’t think the hardware store even had lower options...
And in areas where cars pass over, we were advised to go with 8-10 cm (3-4 inches) wide instead of the usual 5 cm (2 inches).
