ᐅ Height of the floor construction when glueing parquet flooring, with a thickness of 1.5 cm
Created on: 10 Oct 2021 21:26
AllThumbs
AllThumbs
10 Oct 2021 21:26
We need to inform the builder about the height of our future floor construction so that this can be taken into account for the door frames and stairs. We are considering a parquet flooring with a thickness of 1.5cm (0.6 inches).
How thick is the adhesive usually? In other words, what "final height" should I provide to the builder?
Thanks for your help!
K1300S10 Oct 2021 22:22
It’s best to ask the parquet installer. Otherwise, the parquet is sanded after installation, so the adhesive won’t matter in the end... according to our parquet installer.
AllThumbs
10 Oct 2021 22:26
K1300S schrieb:
It’s best to ask the flooring installer. Otherwise, the parquet is usually sanded after installation, so the adhesive doesn’t matter in the end… at least, that’s what our flooring installer says.
We don’t have a flooring installer yet, as we were somewhat surprised by the question and the urgently needed answer. The parquet we chose comes with a factory-applied matte finish and will not be sanded after installation.
However, I will at least call the specialist store where we got the samples tomorrow. I had hoped to clarify this over the weekend.
AllThumbs
11 Oct 2021 09:29
The specialist store estimates 3-4mm (0.1-0.16 inches), but also says it’s best to ask the floor installer – great...
@KlaRa Could you maybe help? From other posts, I gathered that this is exactly your area of expertise. 🙂
K1300S11 Oct 2021 09:58
AllThumbs schrieb:
Specialist store estimates 3-4mm (0.1-0.15 inches)
No way – at least not unless you add some insulation underneath.
AllThumbs
11 Oct 2021 10:53
Do you mean it’s too thick? We would actually prefer something thinner because of the transition to the bathroom tiles.
I also tried to estimate based on the notched trowel used. The “teeth” are about 5mm (0.2 inches) high on average, but I have no idea how much of that remains once the adhesive is pressed down by the parquet.
There will be no insulation underneath; otherwise, the advantage of full-surface bonding would mostly be lost…
